Please I got an Error Compiling. Is this possible to be solved into the code??
C:\Users\USER\Documents\Arduino\libraries\HCPCA9685\HCPCA9685.cpp: In member function 'void HCPCA9685::Init(boolean)':
C:\Users\USER\Documents\Arduino\libraries\HCPCA9685\HCPCA9685.cpp:45: error: 'Wire' was not declared in this scope
I was trying to burn this code:
/* Include the HCPCA9685 library */
#include "HCPCA9685.h"
/* I2C slave address for the device/module. For the HCMODU0097 the default I2C address
is 0x40 */
#define I2CAdd 0x40
/* Create an instance of the library */
HCPCA9685 HCPCA9685(I2CAdd);
/* Initialise the library and set it to 'servo mode' */
HCPCA9685.Init(SERVO_MODE);
/* Wake the device up */
HCPCA9685.Sleep(false);
unsigned int Pos;
/* Sweep the servo back and forth from its minimum to maximum position.
If your servo is hitting its end stops then you should adjust the
values so that the servo can sweep though its full range without hitting
the end stops. You can adjust the min & max positions by altering
the trim values in the libraries HCPCA9685.h file*/
for(Pos = 10; Pos < 450; Pos++)
/* This function sets the servos position. It takes two parameters,
* the first is the servo to control, and the second is the servo
* position. */
HCPCA9685.Servo(0, Pos);
delay(10);
for(Pos = 450; Pos >= 10; Pos--)
delay(10);
