Hcsr04 1-wire protocol
Hello. How to use one wire protocol in 2020 model hcsr04 modules?
hello
Please post the datasheet.
Are you impatient? You should wait 24 hours before kicking your topic; those that might know the answer might be sleeping.
Welcome! You don't, read the data sheet. My answer is based on this:
"The HC-SR04 ultrasonic sensor module interfaces with microcontrollers like Arduino using four pins: VCC, GND, Trig, and Echo. To measure distance, you send a 10µs pulse to the Trig pin, which triggers the sensor to emit ultrasonic waves, and then measure the time it takes for the echo to return on the Echo pin."
I was sleeping when you posted; my computer does not tell me somebody is impatient for an answer.
