I`ve connected the LCD to a max7323 I2C port expander and that to the arduino. After modifying the 4 bit I2C library available elsewhere on here to suit the maxim part, the LCD works great! However I want to try adding some custom characters.
Well I searched around and found lots of information but most of it confused me even more than before so I just have to turn to the pros for help
I found a program to generate the character data, 040E1F0E0E0E0E00. I understand that I have to pull RS low, move to a CGRAM address, RS high again, then fill it with the character data, but I really don`t know where to start :-/
This is the library I`m using.
/* Modified 04/02/09
* AW
* Support Max7323
* removed MCP23008 register addressing
* invert backlight on/off function
#include "LCDI2C4Bit.h"
#include <Wire.h>
extern "C" {
#include <stdio.h> //not needed yet
#include <string.h> //needed for strlen()
#include <inttypes.h>
#include "WConstants.h" //all things wiring / arduino
//command bytes for LCD
#define CMD_CLR 0x01
#define CMD_RIGHT 0x1C
#define CMD_LEFT 0x18
#define CMD_HOME 0x02
//stuff the library user might call---------------------------------
//constructor. num_lines must be 1 or 2, currently.
byte dataPlusMask = 0; // TODO!!!
LCDI2C4Bit::LCDI2C4Bit( int devI2CAddress, int num_lines, int lcdwidth) {
myNumLines = num_lines;
myWidth = lcdwidth;
myAddress = devI2CAddress;
void SetMCPReg( byte deviceAddr, byte reg, byte val ) {
Wire.beginTransmission(deviceAddr);
Wire.send(val);
// Wire.send(val);
Wire.endTransmission();
void SendToLCD( byte deviceAddr, byte data ) {
data |= dataPlusMask;
SetMCPReg(deviceAddr,0x0A,data);
data ^= 0x80; // E
delayMicroseconds(1);
data ^= 0x80; // E
delay(1);
void WriteLCDByte( byte deviceAddr, byte bdata ) {
SendToLCD(deviceAddr,bdata >> 4);
SendToLCD(deviceAddr,bdata & 0x0F);
void LCDI2C4Bit::init( void ) {
dataPlusMask = 0; // initial: 0
// SetMCPReg(myAddress,0x05,0x0C); // set CONFREG (0x05) to 0 not needed for max7323
// SetMCPReg(myAddress,0x00,0x00); // set IOREG (0x00) to 0 not needed
delay(50);
SendToLCD(myAddress,0x03);
delay(5);
delayMicroseconds(100);
delay(5);
SendToLCD(myAddress,0x02);
WriteLCDByte(myAddress,0x28);
WriteLCDByte(myAddress,0x08);
WriteLCDByte(myAddress,0x0C); // turn on, cursor off, no blinking
delayMicroseconds(60);
WriteLCDByte(myAddress,0x01); // clear display
delay(3);
void LCDI2C4Bit::backLight( bool turnOn ) {
dataPlusMask |= 0x40; // Lights mask
if (turnOn) dataPlusMask ^= 0x40;
SetMCPReg(myAddress,0x0A,dataPlusMask);
void LCDI2C4Bit::print( int value ) {
dataPlusMask |= 0x10; // RS
WriteLCDByte(myAddress,(byte)value);
dataPlusMask ^= 0x10; // RS
void LCDI2C4Bit::printIn( char value[] ) {
for ( char *p = value; *p != 0; p++ )
print(*p);
void LCDI2C4Bit::clear() {
commandWrite(CMD_CLR);
void LCDI2C4Bit::cursorTo(int line_num, int x) {
commandWrite(CMD_HOME);
int targetPos = x + line_num * myWidth;
for ( int i = 0; i < targetPos; i++)
commandWrite(0x14);
void LCDI2C4Bit::commandWrite( int command ) {
// RS - leave low
WriteLCDByte(myAddress,command);
delay(1);
