HD44780 : I must reset to get it on
Hi!
It seems my problem is relatively common but I don't really find a way to get it really reliable.
I must reset the arduino to get it on ::slight_smile:
I read something about adding a delay but it was not 100% reliable.
Any idea?
Thanks!
What makes you think that? It is not true.
I ran into that problem myself.
You probably need to use the HD44780 software reset.
Check out the discussion here ...
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1236566774/2#2
Grumpy_Mike : I meant I have to reset the Arduino to see something on the lcd
Mike Rice : Thanks I will try that, the delay are in another location of the file than what I already tried.
I didn't get something reliable with those links but fixed it a hardware way :
My setup is a standalone Arduino.
The problem was that the lcd won't initialise if the voltage is too high.
I simply put my power switch between the regulator and circuit instead of between power jack and regulator.
Hope this can help sometime anyone else. :wink:
