HD44780 LCD + MCP23008 I2C backpack not being detected via I2C
Hi guys,
Using an Arduino MEGA I'm trying to run a HD44780 LCD display that has a MCP23008 I2C backpack and I'm having trouble making it work. I've tried the following (all on pin 20/21 since this seems to be a common mistake):
  • tested the LCD without the backpack and it works fine
  • adding some pull-up resistors to SDA and SCL
  • up to date libraries, and various I2C scanners
All I2C scanners i've tried didn't find the device. Any ideas?
Thanks.
When no I2c scanner is working, there is no valid I2C bus.
Your board: http://arduino.cc/en/Main/arduinoBoardMega2560
Is this your shield ? i2c / SPI character LCD backpack - STEMMA QT / Qwiic : ID 292 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits
Is this the i2c scanner that you have run ? Arduino Playground - I2cScanner
For the mega board, pin 20 is SDA and pin 21 is SCL. Both have already a pullup resistor on the mega board of 10k to +5V.
Are you sure the shield is in I2C mode ?
Can you upload a photo with the wires ?
