HDC1000 Battery Configuration
Hallo,
I am using “HDC1008” sensor with “Arduino UNO”, its a Temperature and Humidity sensor. the data sheet can be found :
I have both prog for “Arduino UNO”, the prog are “Adafruit_HDC1000.h” and “Adafruit_HDC1000.cpp”
In the header file prog “Adafruit_HDC1000.h” written for battery status :
#define HDC1000_CONFIG_BATT   (1 << 11)
and in the data sheet → page 15 → Table 5 says :
in Register 0x02 the bit 11 have to be:
case1: Set(i.e. write 1)–> if we want to make the Battery status–> “Battery voltage < 2.8V (read only)”
case2: unset(i.e. write 0) → if we want to make the Battery status–> “Battery voltage > 2.8V (read only)”
now, my question is how Arduino programmer write 1 << 11 for case1 ? ? ?
I am not saying its wrong… I just want to understand it…
I will appreciate any help. better if any one can explain it clearly with calculation…
Thanks
