Header file giving error "not declared in the scope"
Hello, I'm really new to Arduino and probably trying to run before I can walk. That being said, I'm trying to do something like this guy's video where I want a button press to change the animation on a strip of LEDs. The problem comes in when reformatting existing fastled code (like TwinkleFox) to header files so I can use classes in the main code. I keep getting the error message "_____ not declared in the scope."
Here's the code for the header file. Be warned, it's like 200 lines even after I cut out a lot of the comments and palettes, since I only want to use LavaColors.
#include "Arduino.h"
class LavaTwinkle {
  public:
    LavaTwinkle(){};
    void runPattern();
  private:
    void drawTwinkles( CRGBSet& L);
    void coolLikeIncandescent( CRGB& c, uint8_t phase);
    void chooseNextColorPalette( CRGBPalette16& pal);
#define TWINKLE_SPEED 4
#define TWINKLE_DENSITY 8
#define SECONDS_PER_PALETTE  30
CRGB gBackgroundColor = CRGB::Black;
#define AUTO_SELECT_BACKGROUND_COLOR 0
#define COOL_LIKE_INCANDESCENT 1
CRGBPalette16 gCurrentPalette;
CRGBPalette16 gTargetPalette;
void LavaTwinkle::runPattern() {
 EVERY_N_SECONDS( SECONDS_PER_PALETTE ) {
    chooseNextColorPalette( gTargetPalette );
  EVERY_N_MILLISECONDS( 10 ) {
    nblendPaletteTowardPalette( gCurrentPalette, gTargetPalette, 12);
  FastLED.show();
  chooseNextColorPalette(gTargetPalette);
  btn.tick();
//  This function loops over each pixel, calculates the
//  adjusted 'clock' that this pixel should use, and calls
//  "CalculateOneTwinkle" on each pixel.  It then displays
//  either the twinkle color of the background color,
//  whichever is brighter.
void LavaTwinkle::drawTwinkles( CRGBSet& L) {
  // "PRNG16" is the pseudorandom number generator
  // It MUST be reset to the same starting value each time
  // this function is called, so that the sequence of 'random'
  // numbers that it generates is (paradoxically) stable.
  uint16_t PRNG16 = 11337;
  uint32_t clock32 = millis();
  // Set up the background color, "bg".
  // if AUTO_SELECT_BACKGROUND_COLOR == 1, and the first two colors of
  // the current palette are identical, then a deeply faded version of
  // that color is used for the background color
  CRGB bg;
  if( (AUTO_SELECT_BACKGROUND_COLOR == 1) &&
      (gCurrentPalette[0] == gCurrentPalette[1] )) {
    bg = gCurrentPalette[0];
    uint8_t bglight = bg.getAverageLight();
    if( bglight > 64) {
      bg.nscale8_video( 16); // very bright, so scale to 1/16th
    } else if( bglight > 16) {
      bg.nscale8_video( 64); // not that bright, so scale to 1/4th
      bg.nscale8_video( 86); // dim, scale to 1/3rd.
    bg = gBackgroundColor; // just use the explicitly defined background color
  uint8_t backgroundBrightness = bg.getAverageLight();
  for( CRGB& pixel: L) {
    PRNG16 = (uint16_t)(PRNG16 * 2053) + 1384; // next 'random' number
    uint16_t myclockoffset16= PRNG16; // use that number as clock offset
    // use that number as clock speed adjustment factor (in 8ths, from 8/8ths to 23/8ths)
    uint8_t myspeedmultiplierQ5_3 =  ((((PRNG16 & 0xFF)>>4) + (PRNG16 & 0x0F)) & 0x0F) + 0x08;
    uint32_t myclock30 = (uint32_t)((clock32 * myspeedmultiplierQ5_3) >> 3) + myclockoffset16;
    uint8_t  myunique8 = PRNG16 >> 8; // get 'salt' value for this pixel
    // We now have the adjusted 'clock' for this pixel, now we call
    // the function that computes what color the pixel should be based
    // on the "brightness = f( time )" idea.
    CRGB c = computeOneTwinkle( myclock30, myunique8);
    uint8_t cbright = c.getAverageLight();
    int16_t deltabright = cbright - backgroundBrightness;
    if( deltabright >= 32 || (!bg)) {
      // If the new pixel is significantly brighter than the background color,
      // use the new color.
      pixel = c;
    } else if( deltabright > 0 ) {
      // If the new pixel is just slightly brighter than the background color,
      // mix a blend of the new color and the background color
      pixel = blend( bg, c, deltabright * 8);
      // if the new pixel is not at all brighter than the background color,
      // just use the background color.
      pixel = bg;
void LavaTwinkle::coolLikeIncandescent( CRGB& c, uint8_t phase)
  if( phase < 128) return;
  uint8_t cooling = (phase - 128) >> 4;
  c.g = qsub8( c.g, cooling);
  c.b = qsub8( c.b, cooling * 2);
//  This function takes a time in pseudo-milliseconds,
//  figures out brightness = f( time ), and also hue = f( time )
//  The 'low digits' of the millisecond time are used as
//  input to the brightness wave function.
//  The 'high digits' are used to select a color, so that the color
//  does not change over the course of the fade-in, fade-out
//  of one cycle of the brightness wave function.
//  The 'high digits' are also used to determine whether this pixel
//  should light at all during this cycle, based on the TWINKLE_DENSITY.
CRGB computeOneTwinkle( uint32_t ms, uint8_t salt)
  uint16_t ticks = ms >> (8-TWINKLE_SPEED);
  uint8_t fastcycle8 = ticks;
  uint16_t slowcycle16 = (ticks >> 8) + salt;
  slowcycle16 += sin8( slowcycle16);
  slowcycle16 =  (slowcycle16 * 2053) + 1384;
  uint8_t slowcycle8 = (slowcycle16 & 0xFF) + (slowcycle16 >> 8);
  uint8_t bright = 0;
  if( ((slowcycle8 & 0x0E)/2) < TWINKLE_DENSITY) {
    bright = attackDecayWave8( fastcycle8);
  uint8_t hue = slowcycle8 - salt;
  CRGB c;
  if( bright > 0) {
    c = ColorFromPalette( gCurrentPalette, hue, bright, NOBLEND);
    if( COOL_LIKE_INCANDESCENT == 1 ) {
      coolLikeIncandescent( c, fastcycle8);
    c = CRGB::Black;
  return c;
// This function is like 'triwave8', which produces a
// symmetrical up-and-down triangle sawtooth waveform, except that this
// function produces a triangle wave with a faster attack and a slower decay:
uint8_t attackDecayWave8( uint8_t i)
  if( i < 86) {
    return i * 3;
    i -= 86;
    return 255 - (i + (i/2));
// This function takes a pixel, and if its in the 'fading down'
// part of the cycle, it adjusts the color a little bit like the
// way that incandescent bulbs fade toward 'red' as they dim.
// A palette reminiscent of large 'old-school' C9-size tree lights
// in the five classic colors: red, orange, green, blue, and white.
#define C9_Red    0xB80400
#define C9_Orange 0x902C02
#define C9_Green  0x046002
#define C9_Blue   0x070758
#define C9_White  0x606820
const TProgmemRGBPalette16 RetroC9_p FL_PROGMEM =
{  C9_Red,    C9_Orange, C9_Red,    C9_Orange,
   C9_Orange, C9_Red,    C9_Orange, C9_Red,
   C9_Green,  C9_Green,  C9_Green,  C9_Green,
   C9_Blue,   C9_Blue,   C9_Blue,
   C9_White
// Add or remove palette names from this list to control which color
// palettes are used, and in what order.
const TProgmemRGBPalette16* ActivePaletteList[] = {
  &LavaColors_p,
// Advance to the next color palette in the list (above).
void LavaTwinkle::chooseNextColorPalette( CRGBPalette16& pal)
  const uint8_t numberOfPalettes = sizeof(ActivePaletteList) / sizeof(ActivePaletteList[0]);
  static uint8_t whichPalette = -1;
  whichPalette = addmod8( whichPalette, 1, numberOfPalettes);
  pal = *(ActivePaletteList[whichPalette]);
The errors I keep getting are
 In member function 'void LavaTwinkle::drawTwinkles(CRGBSet&)':
LavaTwinkle.h:91:14: error: 'computeOneTwinkle' was not declared in this scope
In function 'CRGB computeOneTwinkle(uint32_t, uint8_t)':
LavaTwinkle.h:139:14: error: 'attackDecayWave8' was not declared in this scope
LavaTwinkle.h:148:7: error: 'coolLikeIncandescent' was not declared in this scope
LavaTwinkle.h:148:7: note: suggested alternative: 'CoolWhiteFluorescent'
I know this means they need to be stated elsewhere (like the setup? before the setup?) I just... don't know where. Or what variable to use and stuff.
Any help would be appreciated! Thanks in advance!
See My Post #5 in this Thread for a basic guide to breaking a large project into modules.
