Header in library
I'm trying to understand how to create a library with the "Morse" example.
It's rather simple, but I would like to know why the "indef" is written with morse_h instead of morse.h??
I did not find the reason in the documentation or in the more general C tutorials.
Thanks.
...but I would like to know why the "indef" is written with morse_h instead of morse.h??
It is not "indef", it is "ifndef".
#ifndef can be write as #if not defined
It is written as morse_h because you aren't defining the file name, but rather an flag.
So, this code:
#ifndef morse_h
#define morse_h
/* code */
#endif
Can be read as:
If the flag morse_h is not defined, define it and make available the code inside the #if.
If the flag morse_h is already defined, then the code inside the #if won't be available.
This is to prevent errors from multiple includes,
This is called "Include Guard", seach for it.
Thanks for your answer, but this is not exactly what I wanted.
May be I did not explained correctly my question!
I know that this "ifndef" sequence (sorry for misspelling) is to prevent multiple declaration error, it is correctly explained in the tutorial.
What I did not get is why the header file is named Morse.h, and the ifndef is Morse_h.
I suppose that the underscore is interpreted "as a dot", but it looks strange.
It is explicit using the underscore, so it can't be confused with the file.
#ifndef Morse_h
Checks if the flag Morse_h is defined.
See, it doesn't check the if the file is defined, so the name of the flag must be different.
#define Morse_h
This define the flag Morse_h
Again, it must be different from the file name, because it would mean that you are defining the file, but you are just defining a flag.
The names are similar to indicate that this #if is related to the "Include Guard" of Morse.h.
It's a convention. You could call it "MorseDotH_FileExists" instead of "Morse_h" if that makes more sense to you. You can not use a period in the identifier because:
Only alphabetic characters, digits and underscore (_) are permitted in C++ language for declaring identifier.
aarg:
Thanks for sharing this!
Just now I tested with the period in the Include Guard, and I got no errors while compiling and uploading. Maybe it's the Arduino IDE particular characteristic?
#ifndef morse.h
#define morse.h
#endif
#if morse.h
int a = 2;
#else
int a = 1;
#endif
result:
Arduino: 1.6.3 (Windows 7), Board: "Arduino Uno"
sketch_aug15a.ino:2:14: error: token "." is not valid in preprocessor expressions
sketch_aug15a.ino:5:5: note: in expansion of macro 'morse'
Error compiling.
Thanks for your comments.
Now that makes sense!
Have a good day.
Gerard.
This doesn't give me any errors:
# ifndef myLibrary.h
# define myLibrary_h
But this gives:
# define myLibrary.h
Interesting!
