Heading hold
Hi.
I an puting together RoV ( remotley operated vehicle ) comms and sensor bits.
I have CMPS03 compass which gives me a reading of 0-3599 for a full circle, representing 0-359.9 degrees. So no problembs with bit.
I am trying to work out how to implement a compass hold.
I have browsed the forum and found bits but nothing that's of any use or ideas.
The best I have found is here http://arduino.cc/forum/index.php/topic,106683.0.html
I am looking for pointers rather than code as I am still in the learning stages.
Regards Antony
Hi.
After playing I have A excuse for Code.
Some will cry some will say "its a try"
So this is what I have at the moment.
#include "Wire.h"
#include "CMPS03.h"
#include <Servo.h>
CMPS03 cmps03;
#define SERVO  2
Servo    myservo;
int  desiredheading = 55;
int  error;
int val;
  myservo.attach(SERVO);
  Wire.begin();
  error = desiredheading - (cmps03.read());
  if(error < - 1800) error =(3600 + error);
  else if(error > 1800) error =(- 3600 - error);       // output here is between -1800 +1800
  val = map(error, -1800, 1800, 0, 180);         // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);
  Serial.print(" error =  ");
  Serial.print(error);
  Serial.print("                        Servo = ");
  Serial.println(val);
  delay(200);
The issue I face ATM is if my true heading is 310 degrees and I need to turn to 55 degrees via the shortest turn..this works until it goes past North 0 360.
At this point the servo runs away and I have no idea on how to overcome this issue.
Any thoughts on this would be really helpful and encouraging.
Regards Antony.
had a look at your code. Did a quick refactor , find the 7 differences ;).
One bug was that the desired heading should be in 1/10th of degrees too.
Code compiles => Give it a try.
//    FILE: compass.pde
//  AUTHOR:
//    DATE: 2012-06-04
// PUPROSE: keeping heading
#include "Wire.h"
#include "CMPS03.h"
#include <Servo.h>
CMPS03 cmps03;
#define SERVO  2
Servo    myservo;
int  desiredheading = 550;  // must be in 1/10th degree as compass is also in 1/10th
int val = 90;
  Wire.begin();
  myservo.write(val);
  // average 4 readings to remove noise.
  int heading = 0;
  for (int i=0; i<4; i++) heading += cmps03.read();
  heading /= 4;
  int error = desiredheading - heading;
  if (abs(error) >= 20) // NOTE: |error| < 20 will not pass the map function!
    if (error < -1800) error += 3600;
    else if (error > 1800) error -= 3600;
    // shorter formula
    // val = error/20 + 90;
    myservo.write(val);
  Serial.print("  heading =  ");
  Serial.print(heading);
  Serial.print("  desiredheading =  ");
  Serial.print(desiredheading );
  delay(200);
Hi Rob.
I picked up the first one 1/10 degrees. This helped
But the read the compass 4 times then devide bu 4 gives me what I wanted...THANKS.
I have the test rig with Arduino uno Cmps03 and a micro servo mounted in a board.
when I turn the board the Servo(rudder) correct's the error.
Thats all I wanted from this sketch...
Thanks Antony.
Almost every sensor I know has noise, some more than others. By oversampling / averaging the noise is made less.
Good to hear the sketch is working, however as I pointed out small deviations less than 20 are currently not corrected for.
The first way to handle this is to introduce proper rounding.
Another - heuristic - approach is to make an estimate of the sum of the error e.g. 10 seconds @ -0.5 degree (which cannot be done by the servo) could be corrected by 4 seconds @ -1 degree (which can be done by the servo). The numbers can be found by some triangel / sine() math or by trial and error...
Hi Rob.
The output from this sketch will be feed into the thrusters to correct headings.
As the output is at the moment it's perfect.
Just for people's intrest:-
It works like this If I move rhe RoV around then don't move the joystick the Arduino will take a heading and this will be it goal to hold.
Thrusters are controlled by Esc(revirseable).
Also the Depth will have a Auto hold.
Again thank You.
Regards Antony.
