Im makeing a headlamp from scratch with several functions.
The headlamp will have several light sources controlled by an Atmega328 and two push buttons.
Push button 1:
- First press: LED 1 at 50% brightes
- Second press: LED 1 at 100% brightnes
- Third press: LED 2 at 50% brightnes (and LED 1 off)
- Forth press: LED 2 at 100% brightnes
- Fifth press: LED 1 and 2 at 50%
- Sixth press: LED 1 and 2 at 100%
- Seventh press: All off
Push button 2:
- First press: Show battery level for 5 seconds (5 LEDs connected to 5 digital outputs, and battery level connected to one analog input)
- Second press: RGB RED at 100% (and all other LEDs off)
- Forth press: RGB GREEN at 100% (and all other LEDs off)
- Fift press: RGB BLUE at 100% (and all other LEDs off)
- Sixth press: All off
I also want Push button 1 to turn off all "Push button 2 lights" when pressed and vice versa.
Excample:
Push button 1 is pushed two times turnes LED 1 on at 100%, but if I then push button 2 one time, LED 1 turns off and first "case" for push button 1 starts (battery indicator).
I have made a code using switch case and it works fine for one push button, but I dont know how to add a secon button and code it like I described over. Also if I use "Digital High - delay Digital Low - delay" in a case I cant jump to the next case using the pushbutton?
Is switch case the correct thing to use here, or should I use something else?
Can I use PWM in a case to set a LED at 50%?
Thanks
