Heart rate and Spo2 Sensor problem!
Hello every one here , i am here again :slight_smile:
I am dealing with HR & Spo2 Sensor "MAX30102" bought new one but it didn't worked, after doing some edits on the board by removing the SMD resistors and replace them with external Pull-up resistors 4.7k on SDA & SCL so it's worked finally!
My problem now that i can't get the average of heart rate (The Spo2 reading is very well but HR reading is too bad depends on the library of sparkfun and the standard code of Spo2 with HR). I failed in make the average HR getting value by using multiple formulas but no result.
Here is my code:
#include <Wire.h>
#include "MAX30105.h"
#include "spo2_algorithm.h"
#include "heartRate.h"
#include "MLX90615.h"
#include <I2cMaster.h>
MAX30105 particleSensor;
#define MAX_BRIGHTNESS 255
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
//Arduino Uno doesn't have enough SRAM to store 100 samples of IR led data and red led data in 32-bit format
//To solve this problem, 16-bit MSB of the sampled data will be truncated. Samples become 16-bit data.
uint16_t irBuffer[100]; //infrared LED sensor data
uint16_t redBuffer[100];  //red LED sensor data
#else
uint32_t irBuffer[100]; //infrared LED sensor data
uint32_t redBuffer[100];  //red LED sensor data
#endif
int32_t bufferLength; //data length
int32_t spo2; //SPO2 value
int8_t validSPO2; //indicator to show if the SPO2 calculation is valid
int32_t heartRate; //heart rate value
int8_t validHeartRate; //indicator to show if the heart rate calculation is valid
byte pulseLED = 11; //Must be on PWM pin
byte readLED = 13; //Blinks with each data read
#define SDA_PIN 4   //define the SDA pin
#define SCL_PIN 5   //define the SCL pin
SoftI2cMaster i2c(SDA_PIN, SCL_PIN);
MLX90615 mlx90615(DEVICE_ADDR, &i2c);
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
  Serial.begin(115200); // initialize serial communication at 115200 bits per second:
  Serial1.begin(9600);
  pinMode(pulseLED, OUTPUT);
  pinMode(readLED, OUTPUT);
  // Initialize sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
    Serial.println(F("MAX30105 was not found. Please check wiring/power."));
    while (1);
  Serial.println(F("Attach sensor to finger with rubber band. Press any key to start conversion"));
  while (Serial.available() == 0) ; //wait until user presses a key
  Serial.read();
  byte ledBrightness = 60; //Options: 0=Off to 255=50mA
  byte sampleAverage = 4; //Options: 1, 2, 4, 8, 16, 32
  byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
  byte sampleRate = 100; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
  int pulseWidth = 411; //Options: 69, 118, 215, 411
  int adcRange = 4096; //Options: 2048, 4096, 8192, 16384
  particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
  particleSensor.setPulseAmplitudeRed(0x0A); //Turn Red LED to low to indicate sensor is running
  particleSensor.setPulseAmplitudeGreen(0); //Turn off Green LED
  bufferLength = 100; //buffer length of 100 stores 4 seconds of samples running at 25sps
  //read the first 100 samples, and determine the signal range
  for (byte i = 0 ; i < bufferLength ; i++)
    while (particleSensor.available() == false) //do we have new data?
      particleSensor.check(); //Check the sensor for new data
    redBuffer[i] = particleSensor.getRed();
    irBuffer[i] = particleSensor.getIR();
    particleSensor.nextSample(); //We're finished with this sample so move to next sample
    Serial.print(F("red="));
    Serial.print(redBuffer[i], DEC);
    Serial.print(F(", ir="));
    Serial.println(irBuffer[i], DEC);
  //calculate heart rate and SpO2 after first 100 samples (first 4 seconds of samples)
  maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
  //Continuously taking samples from MAX30102.  Heart rate and SpO2 are calculated every 1 second
  while (1)
    //dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
    for (byte i = 25; i < 100; i++)
      redBuffer[i - 25] = redBuffer[i];
      irBuffer[i - 25] = irBuffer[i];
    //take 25 sets of samples before calculating the heart rate.
    for (byte i = 75; i < 100; i++)
      digitalWrite(readLED, !digitalRead(readLED)); //Blink onboard LED with every data read
      //Check if no finger?
      if (redBuffer[i] < 5000 & irBuffer[i] < 5000) {
        Serial.print("No Finger!");
        Serial.println("    ");
        Serial1.write("5");
      else {
        //send samples and calculation result to terminal program through UART
        Serial.print(irBuffer[i], DEC);
        Serial.print(F(", HR="));
        Serial.print(heartRate, DEC);
        Serial.print(F(", HRvalid="));
        Serial.print(validHeartRate, DEC);
        Serial.print(F(", SPO2="));
        Serial.print(spo2, DEC);
        Serial.print(F(", SPO2Valid="));
        Serial.print(validSPO2, DEC);
        Serial.print(F(", Object temperature: "));
        Serial.println(mlx90615.getTemperature(MLX90615_OBJECT_TEMPERATURE));
        Serial1.print("<Serial1"); Serial1.print(","); Serial1.print(spo2); Serial1.print(","); Serial1.print(heartRate); Serial1.print(","); Serial1.print(mlx90615.getTemperature(MLX90615_OBJECT_TEMPERATURE)); Serial1.print(">");
    //After gathering 25 new samples recalculate HR and SP02
and here is the formula i've used to get the average HR :
// ============ Heart Rate
  long irValue = particleSensor.getIR();
  Serial.print("IR NEW");
  Serial.println(irValue);
  if (checkForBeat(irValue) == true)
    //We sensed a beat!
    long delta = millis() - lastBeat;
    lastBeat = millis();
    beatsPerMinute = 60 / (delta / 1000.0);
    if (beatsPerMinute < 255 && beatsPerMinute > 20)
      rates[rateSpot++] = (byte)beatsPerMinute; //Store this reading in the array
      rateSpot %= RATE_SIZE; //Wrap variable
      //Take average of readings
      beatAvg = 0;
      for (byte x = 0 ; x < RATE_SIZE ; x++)
        beatAvg += rates[x];
      beatAvg /= RATE_SIZE;
  // ============== Heart Rate
but no result
Explain.
The value of average HR is always "0".
What do the debug prints show?
No debugs , No error!
Uploading done! and average HR is [zero] just HR value show a bad readings.
Note: While using the code of HR and average HR only without Spo2 code its working and show a correct readings for average HR.
I don't know what do you means by "debug" but it prints decimal values for IR and RED IR reading for the sensor MAX30102 and the rest of readings depends on them.
mi_ds:
"debug" in this sense means "performs no useful thing except help debug the rest of the software"
No debug prints show
Time to add some more then.
Add a "hello world" after initialising the serial port, and make sure the line speed in the serial monitor matches that in the sketch.
Then walk down the code adding unique prints at all the key stages of the sketch.
If you can confrim that your Serial Comms is OK, have a look at this library's example; it seems to do what you are trying to achieve.
I've cleaned the example code a bit for just writing to serial Monitor if you want to try it (untested!!!):
#define DEBUG // Uncomment for debug output to the Serial stream
#define TEST_MAXIM_ALGORITHM // Uncomment if you want to include results returned by the original MAXIM algorithm
#include <Arduino.h>
#include <Wire.h>
#include <SPI.h>
#include "algorithm_by_RF.h"
#include "max30102.h"
#ifdef TEST_MAXIM_ALGORITHM
  #include "algorithm.h"
#endif
// Interrupt pin
const byte oxiInt = 10; // pin connected to MAX30102 INT
uint32_t elapsedTime,timeStart;
uint32_t aun_ir_buffer[BUFFER_SIZE]; //infrared LED sensor data
uint32_t aun_red_buffer[BUFFER_SIZE];  //red LED sensor data
float old_n_spo2;  // Previous SPO2 value
uint8_t uch_dummy,k;
  pinMode(oxiInt, INPUT);  //pin D10 connects to the interrupt output pin of the MAX30102
  Wire.begin();
#ifdef DEBUG
#endif
  maxim_max30102_reset(); //resets the MAX30102
  maxim_max30102_read_reg(REG_INTR_STATUS_1,&uch_dummy);  //Reads/clears the interrupt status register
  maxim_max30102_init();  //initialize the MAX30102
  old_n_spo2=0.0;
  timeStart=millis();
//Continuously taking samples from MAX30102.  Heart rate and SpO2 are calculated every ST seconds
  float n_spo2,ratio,correl;  //SPO2 value
  int8_t ch_spo2_valid;  //indicator to show if the SPO2 calculation is valid
  int32_t n_heart_rate; //heart rate value
  int8_t  ch_hr_valid;  //indicator to show if the heart rate calculation is valid
  int32_t i;
  char hr_str[10];
  //buffer length of BUFFER_SIZE stores ST seconds of samples running at FS sps
  //read BUFFER_SIZE samples, and determine the signal range
  for(i=0;i<BUFFER_SIZE;i++)
    while(digitalRead(oxiInt)==1);  //wait until the interrupt pin asserts
    maxim_max30102_read_fifo((aun_red_buffer+i), (aun_ir_buffer+i));  //read from MAX30102 FIFO
#ifdef DEBUG
    Serial.print(i, DEC);
    Serial.print(F("\t"));
    Serial.print(aun_red_buffer[i], DEC);
    Serial.print(aun_ir_buffer[i], DEC);
    Serial.println("");
#endif // DEBUG
  //calculate heart rate and SpO2 after BUFFER_SIZE samples (ST seconds of samples) using Robert's method
  rf_heart_rate_and_oxygen_saturation(aun_ir_buffer, BUFFER_SIZE, aun_red_buffer, &n_spo2, &ch_spo2_valid, &n_heart_rate, &ch_hr_valid, &ratio, &correl);
  elapsedTime=millis()-timeStart;
  elapsedTime/=1000; // Time in seconds
#ifdef DEBUG
  Serial.println("--RF--");
  Serial.print(elapsedTime);
  Serial.print("\t");
  Serial.print(n_spo2);
  Serial.print("\t");
  Serial.print(n_heart_rate, DEC);
  Serial.print("\t");
  Serial.println(hr_str);
  Serial.println("------");
#endif // DEBUG
  //calculate heart rate and SpO2 after BUFFER_SIZE samples (ST seconds of samples) using MAXIM's method
  float n_spo2_maxim;  //SPO2 value
  int8_t ch_spo2_valid_maxim;  //indicator to show if the SPO2 calculation is valid
  int32_t n_heart_rate_maxim; //heart rate value
  int8_t  ch_hr_valid_maxim;  //indicator to show if the heart rate calculation is valid
  maxim_heart_rate_and_oxygen_saturation(aun_ir_buffer, BUFFER_SIZE, aun_red_buffer, &n_spo2_maxim, &ch_spo2_valid_maxim, &n_heart_rate_maxim, &ch_hr_valid_maxim);
#ifdef DEBUG
  Serial.println("--MX--");
  Serial.print("\t");
  Serial.print(n_spo2_maxim);
  Serial.print("\t");
  Serial.print(n_heart_rate_maxim, DEC);
  Serial.print("\t");
#endif // DEBUG
#endif // TEST_MAXIM_ALGORITHM
  //save samples and calculation result to SD card
  if(ch_hr_valid && ch_spo2_valid || ch_hr_valid_maxim && ch_spo2_valid_maxim) {
#else   // TEST_MAXIM_ALGORITHM
  if(ch_hr_valid && ch_spo2_valid) {
    old_n_spo2=n_spo2;
AWOL:
What is the type of problem could be happened if the other readings is right?
sherzaad:
GitHub - aromring/MAX30102_by_RF: Arduino C code for MAX30102 pulse oximetry sensor (MAXIM Integrated, Inc.)
#include <Wire.h>
#include <SPI.h>
#endif
// Interrupt pin
Wire.begin();
#ifdef DEBUG
#endif
  old_n_spo2=0.0;
  timeStart=millis();
  int32_t i;
  char hr_str[10];
#ifdef DEBUG
    Serial.println("");
#endif // DEBUG
#ifdef DEBUG
  Serial.print("\t");
  Serial.print("\t");
  Serial.print("\t");
#endif // DEBUG
#ifdef DEBUG
  Serial.print("\t");
  Serial.print("\t");
  Serial.print("\t");
#endif // DEBUG
    old_n_spo2=n_spo2;
Tested.. I think it works but it takes [100 readings of ir and red ir] for [every 1 reading of heart rate and spo2] so don't see the changes in heart rate and spo2 even stopped autoscroll.
Anybody?
If you miss a beat then last beat will be way off. Try...
bool hasLastbeat = false; // declare global start
    //We sensed a beat!
    if (beatsPerMinute < 255 && beatsPerMinute > 20 && hasLastBeat)
      hasLastBeat = true;
      beatAvg = 0;
    else hasLastBeat = false;
ee_es_pe:
    //We sensed a beat!
      hasLastBeat = true;
      beatAvg = 0;
Tested.. Also Average still zero!
Here is the code:
#include <Wire.h>
#else
#endif
byte rateSpot = 0;
int beatAvg;
    while (1);
  Serial.read();
  while (1)
      bool hasLastBeat = false; // declare global start
        //We sensed a beat!
          hasLastBeat = true;
          beatAvg = 0;
        Serial1.write("5");
      else {
        Serial.print(F(", AVG="));
        Serial.print(beatAvg, DEC);
  void HR() {
Try this
#include <Wire.h>
#else
#endif
long beatSum = 0;
int beatSamples = 0;
int beatAvg;
    while (1);
  Serial.read();
  while (1)
      if(validHeartRate)
        beatSum += heartRate;
        beatSamples++;
        beatAvg = beatSum / beatSamples;
        Serial1.write("5");
      else {
ee_es_pe:
Try this
#include <Wire.h>
#if defined(AVR_ATmega328P) || defined(AVR_ATmega168)
#else
#endif
long beatSum = 0;
int beatAvg;
    while (1);
  Serial.read();
  while (1)
      if(validHeartRate)
        beatSamples++;
        Serial1.write("5");
      else {
Tested.. Average beat not accurate reading about 160 bpm because [validHeartRate] reading not accurate also.
mi_ds:
What value is validHeartRate? It & validSPO2 should be 1 if it thinks the data is correct.
ee_es_pe:
It is "1" but not means the data is correct.
