Heat detector Project Help me please
Currently I carry around to test the heat detectors in my buildings. I'd like to build something portable that runs on a 9-12V power supply.
please somebody help me to write a code for use to control heat detectors
this is accessories in my heat detector
1 Aduino uno bord
2 lcd nokia 5110
3 Alarm
4 Sensor Heat detector
5 Ethernet bord to transmission get in Main sever
The work heat detector
1 temperature display nokia 5110
2 temperature ALARM
This is all control by aduino uno bord
jonatanpp:
1 Aduino uno bord
2 lcd nokia 5110
3 Alarm
2 temperature ALARM
1)what is working environment??
2) what are the specification of heat detector/limitations??
3)What is temperature working environment and when do you want alarm to trigger??
4)which Ethernet shield being used??
RE quest
1 Environment in building. tempurature around 30 degree Celsius
2 Specification of heat detector is CM-WS19L/limitations IS temperature change 10 degree Celsius per minute
3 If temperature change 10 degree Celsius per minute Indefinitely,Alarm to trigger
4 Ethernet shield being used is Arduino Ethernet shield
AMPS-N:
jonatanpp:
1 Aduino uno bord
2 lcd nokia 5110
3 Alarm
2 temperature ALARM
How to write code control lcd nokia 5110 for display temperature or who can write code?
1 nokia 5110 lcd
2 bord arduino
3 heat sensor CM-WS19L
http://enchchok.tarad.com/product-en-969932-5110295-Rate+of+Rise+Heat+Detector+,Model+CM+WS19L+,+CM+(Taiwan).html
How to write code control heat sensor CM-WS19L by arduino bord or who can write code?
How to write code control heat sensor CM-WS19L by arduino bord for Alarm or who can write code?
Heat detector
@jonatanpp, please stop cross-posting.
If I understand things correctly this is not a portable detector - it is intended to stay in one place. So I'm not sure what you are trying to do.
If you are trying to create a device that will prove that the detector is working properly won't you need something that causes it to experience a sudden rise in ambient temperature?
...R
