hi everybody. i want to control my heater.İ have bluetooth module,relay module and ds18b20.
float temperature = getTemp();
float tempF = (temperature);
Serial.println(tempF);
delay(2000); //Checking new value
if(Serial.available()) //bluetooth connection
int data = Serial.read();
delay(100);
// i send the data from my phone. for ex: temp = 25 i send 20, relay off . i want to control my heater...
if ( tempF <= data )
digitalWrite(RELAY1,HIGH);
else if (tempF >= data)
digitalWrite(RELAY1,LOW);
ths is true ? code is true but i try on the breadboard not working.
full code:
#include <OneWire.h>
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
int RELAY1 =3;
OneWire ds(DS18S20_Pin); // on digital pin 2
void setup(void) {
void loop(void) {
delay(100);
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
return TemperatureSum;
