int PPR = 4 // PPR- speed pulses per wheel revolution
int TC = 1954 // TC- tire circumference
volatile int rpmcalc // rpmcalc rpm pulses in interrupt
volatile int speedcalc // speedcalc speed pulses in interrupt
volatile unsigned long timestop // timestop rpm stop times in microseconds
volatile unsigned long timestop2 // timestop2 speed stop times in microseconds
unsigned long timeold = 0L // timekeeping var for rpms in microseconds
unsigned long timeold2 = 0L // timekeeping var for speed in microseconds
int SL1 = 22 // shift lights SL1-15 specifies pins 22-36
int SL2 = 23
int SL3 = 24
int SL4 = 25
int SL5 = 26
int SL6 = 27
int SL7 = 28
int SL8 = 29
int SL9 = 30
int SL10 = 31
int SL11 = 32
int SL12 = 33
int SL13 = 34
int SL14 = 35
int SL15 = 36
unsigned int rpm = 0
unsigned int speed = 0
void setup ()
{ // set pins SL1-SL15 as output
pinMode(SL1, output);
pinMode(SL2, output);
pinMode(SL3, output);
pinMode(SL4, output);
pinMode(SL5, output);
pinMode(SL6, output);
pinMode(SL7, output);
pinMode(SL8, output);
pinMode(SL9, output);
pinMode(SL10, output);
pinMode(SL11, output);
pinMode(SL12, output);
pinMode(SL13, output);
pinMode(SL14, output);
pinMode(SL15, output);
attachInterrupt (0, rpmcalc, rising);
// specifying the interrupt name- rpmcalc, the interrupt pin to watch- 0, and the state to watch for- rising
attachInterrupt (1, speedcalc, rising);
// specifying the interrupt name- speedcalc, the interrupt pin to watch- 1, and the state to watch for- rising
void loop ()
{ // First is the RPM calculations
if (rpmcalc >= 1)
rpm = 2 * rpmcalc * 60 * 1000000 / (timestop - timeold)
// calculates rpm from the change in microseconds between pulses. micros return the number of microseconds the program has been running. timeold which is initially 0 marks the time of the last pulse
timeold = timestop;
rpmcalc = 0;
// resets the timer then waits for the next pulse
// Second is shift lights illumination. I have it set up to turn the first 5 LEDS sequentially from 5000, 6000, 7000, 8000, 9000. Then the next set of 5 LEDS on at 10000 (as a pre shift light). Finally, the final 5 LEDS on at 10900.
// First, turn all the shift lights to off
digitalWrite (SL1, LOW);
digitalWrite (SL2, LOW);
digitalWrite (SL3, LOW);
digitalWrite (SL4, LOW);
digitalWrite (SL5, LOW);
digitalWrite (SL6, LOW);
digitalWrite (SL7, LOW);
digitalWrite (SL8, LOW);
digitalWrite (SL9, LOW);
digitalWrite (SL10, LOW);
digitalWrite (SL11, LOW);
digitalWrite (SL12, LOW);
digitalWrite (SL13, LOW);
digitalWrite (SL14, LOW);
digitalWrite (SL15, LOW);
if (rpm > 10900)
{ // turn on all shift lights
digitalWrite (SL1, HIGH);
digitalWrite (SL2, HIGH);
digitalWrite (SL3, HIGH);
digitalWrite (SL4, HIGH);
digitalWrite (SL5, HIGH);
digitalWrite (SL6, HIGH);
digitalWrite (SL7, HIGH);
digitalWrite (SL8, HIGH);
digitalWrite (SL9, HIGH);
digitalWrite (SL10, HIGH);
digitalWrite (SL11, HIGH);
digitalWrite (SL12, HIGH);
digitalWrite (SL13, HIGH);
digitalWrite (SL14, HIGH);
digitalWrite (SL15, HIGH);
else if (rpm >= 10000)
{ // turn on first 10 shift lights
else if (rpm >= 9000)
{ // turn on first 5 shift lights
else if (rpm >= 8000)
{ // turn on first 4 shift lights
else if (rpm >= 7000)
{ // turn on first 3 shift lights
else if (rpm >= 6000)
{ // turn on first two shift lights
else if (rpm >= 5000)
{ // turn on first one shift light
// Third- speed display calculations
if (speedcalc >= 10)
{ // waits for 10 speed pulses before updating the speed display. Can change this up or down to speed up refresh rates of speed display
speed = 10 * TC * 3600 / ((timestop2 - timeold2) * PPR * 1609)
// calculates speed from the change in microseconds between pulses. micros return the number of microseconds the program has been running. timeold which is initially 0 marks the time of the last pulse
timeold2 = timestop2;
speedcalc = 0;
// Last is gear indicator will refresh every 10 speed pulses. Calculating rpm/mph in each gear with a 190/55/17 tires results in: gear 1- 157, gear 2- 115, gear 3- 90, gear 4- 80, gear 5- 71, gear 6- 63
gearratio = rpm / speed
if (gearratio > 147 && gearratio < 167) gearpos = 1;
else if (gearratio > 105 && gearratio < 125) gearpos = 2;
else if (gearratio > 85 && gearratio < 95) gearpos = 3;
else if (gearratio > 75 && gearratio < 85) gearpos = 4;
else if (gearratio > 67 && gearratio < 75) gearpos = 5;
else if (gearratio > 60 && gearratio < 66) gearpos = 6;
else gearpos = 0 // using this to debug. the calculations did not work
rpmcalc ()
{ // this is the interrupt subprogram. when the pulse comes to interrupt 0, it stops the main program even stops the micros counter and runs this subprogram
rpmcalc ++;
// this counts the number of pulses by adding one to rpmcalc
timestop = micros();
// this captures the time the pulse was read
speedcalc ()
{ // this is the interrupt subprogram. when the pulse comes to interrupt pin 1, it stops the main program even stops the micros counter and runs this subprogram
speedcalc ++;
timestop2 = micros();
