Hello Arduino
I have a code in which you can have a "conversation" with your arduino. I am in the process of typing it and when I checked if what I typed so far made sense there were a few errors I was just wondering if you can help me.
    delay(25);
  if(Serial.available()){
  Serial.print("Hello! I'm U.N.O. how are you?");
  delay(2000);
  Serial.print('\n'"type 1, 2, 3 or 4");
  delay(5000);
  Serial.print('\n'"1: Good");
  Serial.print('\n'"2: Bad");
  Serial.print('\n'"3: Okay");
  Serial.print('\n'"4: Great!");
  delay(25);
The errors were:
HelloArduino.ino: In function 'void setup()':
HelloArduino:7: error: expected `)' before string constant
HelloArduino:9: error: expected `)' before string constant
HelloArduino:11: error: expected `)' before string constant
HelloArduino:13: error: expected `)' before string constant
HelloArduino:15: error: expected `)' before string constant
Thanks in advance!
(deleted)
spycatcher2k:
this does not make sense :
try
Serial.print("\ntype 1, 2, 3 or 4");
Thank you sir...
for helping a noob out.
(deleted)
spycatcher2k:
Errr - I'm not a Sir!
Uh Oh...
Run!!!!
I need more help please.
  delay(2000);
  Serial.print('\n');
  delay(50);
  Serial.print("type 1, 2, 3 or 4");
  delay(2000);
  Serial.print('\n');
  delay(50);
  Serial.print("1: Good");
  delay(2000);
  Serial.print('\n');
  delay(50);
  Serial.print("2: Bad");
  delay(2000);
  Serial.print('\n');
  delay(50);
  Serial.print("3: Okay");
  delay(2000);
  Serial.print('\n');
  delay(50);
  Serial.print("4: Great!");
  delay(2000);
  Serial.print('\n');
 if (Serial.read(49)) {
          Serial.print("");
The errors are:
HelloArduino.ino: In function 'void loop()':
HelloArduino:30: error: no matching function for call to 'HardwareSerial::read(int)'
/Users/sharma/Desktop/ .app/Contents/Resources/Java/hardware/arduino/cores/arduino/HardwareSerial.h:60: note: candidates are: virtual int HardwareSerial::read()
HelloArduino:32: error: expected unqualified-id before '}' token
HelloArduino:32: error: expected `;' before '}' token
Serial.read() returns a character, it doesn't return true/false, so you don't pass it a value to check it against, you check if the return value equals a constant.
Ciao I suggest to you ...
you can start to play with ASCII CODE and take confidence :slight_smile:
then use the example that is present into arduino ide,
regards,
Andrea
Shazam360:
  delay(2000);
  Serial.print('\n');
  delay(50);
  delay(2000);
  Serial.print('\n');
  delay(50);
  delay(2000);
  Serial.print('\n');
  delay(50);
  delay(2000);
  Serial.print('\n');
  delay(50);
  delay(2000);
  Serial.print('\n');
  delay(50);
  delay(2000);
  Serial.print('\n');
          Serial.print("");
The errors are:
 if (Serial.available())
     char myChar = Serial.read();
     Serial.println(myChar);
