Hello, can anyone explain to me how to control BTS7960?
Hello, can anyone explain to me how to control the BTS7960? I am an amateur and I can not understand whether in order for the motor to rotate, you need to feed the high level to the pin each time to choose the direction of rotation after the PWM pin itself? What does it look like in the case of a joystick, for example?
Have you seen this data sheet?
Oops! That page can’t be found.
Nothing was found at this location. Try searching, or check out the links below.
I don't know if I will understand anyway, I am a novice in programming.
Hopefully I fixed that link above.
Have a look, it's a more beginner-friendly kind of data sheet than those of professional products.
Ignore the schematic at the top of page 3, I think that's an error, or at least very confusing.
If that's no help, try re-phrasing and elaborating on your question.
I found this part of your question confusing:
Also please clarify what model of joystick you are asking about, post a link to it.
I don't understand NOTHING of it. Elsewhere I saw that pins 3,4 are connected to the arduino and are used to mark the direction of rotation, here they are connected to 5V ...
