#include <SPI.h> //Library for SPI communication (Pre-Loaded into Arduino)
#include <SD.h> //Library for SD card (Pre-Loaded into Arduino)
#include <SFE_BMP180.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <TinyGPS.h>
SFE_BMP180 bmp180;
TinyGPS gps;
SoftwareSerial serialgps (4,3);
const int chipSelect = 10; //SD card CS pin connected to pin 4 of Arduino
int year;
byte month, day, hour, minute, second, hundredths;
unsigned long chars;
unsigned short sentences, failed_checksum;
// Setup Serial connection
//Setup GPS
serialgps.begin(9600);
Serial.println("");
Serial.println("GPS NEO6MV");
Serial.println("Buscando seƱal...");
Serial.println("");
//CODI SD
pinMode(chipSelect, OUTPUT);
Initialize_SDcard();
//CODI BMP180
if (bmp180.begin())
Serial.println("BMP180 iniciado correctamenten");
Serial.println("Error al iniciar el BMP180");
while(1); // bucle infinito
//CODI GPS
while(serialgps.available())
int c = serialgps.read();
if (gps.encode(c))
float latitude, longitude;
File dataFile = SD.open("Datos.txt", FILE_WRITE);
if (dataFile)
gps.f_get_position(&latitude, &longitude);
Serial.print("Latitud/Longitud: ");
dataFile.print("Latitud/Longitud: ");
Serial.print(latitude, 5);
dataFile.print(latitude, 5);
Serial.print(", ");
dataFile.print(", ");
Serial.println(longitude, 5);
dataFile.println(longitude, 5);
gps.crack_datetime(&year,&month,&day,&hour,&minute,&second,&hundredths);
Serial.print("Fecha: "); Serial.print(day, DEC); Serial.print("/");
Serial.print(month, DEC); Serial.print("/"); Serial.println(year);
Serial.print("Hora: "); Serial.print(hour, DEC); Serial.print(":");
dataFile.print("Hora: "); dataFile.print(hour, DEC); dataFile.print(":");
Serial.print(minute,DEC); Serial.print(":"); Serial.print(second,DEC);
dataFile.print(minute,DEC); dataFile.print(":"); dataFile.print(second,DEC);
Serial.print("."); Serial.println(hundredths,DEC);
dataFile.print("."); dataFile.println(hundredths,DEC);
Serial.print("Altitud (metros): "); Serial.println(gps.f_altitude());
dataFile.print("Altitud (metros): "); dataFile.println(gps.f_altitude());
Serial.print("Rumbo (grados): "); Serial.println(gps.f_course());
dataFile.print("Rumbo (grados): "); dataFile.println(gps.f_course());
Serial.print("Velocidad (kmph): "); Serial.println(gps.f_speed_kmph());
dataFile.print("Velocidad (kmph): "); dataFile.println(gps.f_speed_kmph());
Serial.print("Satelites: "); Serial.println(gps.satellites());
dataFile.print("Satelites: "); dataFile.println(gps.satellites());
dataFile.println();
gps.stats(&chars, &sentences, &failed_checksum);
dataFile.close(); //Close the file
char status;
double T,P;
status = bmp180.startTemperature();//Inicio de lectura de temperatura
if (status != 0)
delay(status); //Pausa para que finalice la lectura
status = bmp180.getTemperature(T); //Obtener la temperatura
if (status != 0)
status = bmp180.startPressure(3); //Inicio lectura de presión
if (status != 0)
delay(status);//Pausa para que finalice la lectura
status = bmp180.getPressure(P,T); //Obtenemos la presión
if (status != 0)
if (dataFile)
Serial.print("Temperatura: ");
dataFile.print("Temperatura: ");
Serial.print(T,2);
dataFile.print(T,2);
Serial.print(" *C , ");
dataFile.print(" *C , ");
Serial.print("Presion: ");
dataFile.print("Presion: ");
Serial.print(P,2);
dataFile.print(P,2);
Serial.println(" mb");
dataFile.println(" mb");
dataFile.close();
Serial.println("File not writing");
delay(1000); //Wait for 5 seconds before writing the next data
void Initialize_SDcard()
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect))
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("Card present");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
// if the file is available, write to it:
if (dataFile)
dataFile.println("Datos:"); //Write the first row of the excel file
dataFile.close();
Serial.println("File writing");
Show the full error just like you showed the full sketch (in a < CODE > block)
Your file "Datos.txt" could not be opened. Verify your wiring and the SD card reader has sufficient power.
Well actually if I run the code just with the BMP180 and the SD the code runs perfectly and save the information.
#include <Wire.h>
SFE_BMP180 bmp180;
int num = 0;
//CODI BMP180
if (bmp180.begin())
char status;
double T,P;
if (status != 0)
if (status != 0)
if (status != 0)
if (status != 0)
if (dataFile)
Serial.print(T,2);
Serial.print(P,2);
dataFile.close();
return;
if (dataFile)
dataFile.println("Temperature,Humidity"); //Write the first row of the excel file
dataFile.close();
but when I add the GPS code is when all the code dies, so in theory the file "Datos.txt" is working well. I think the problem when I add the GPS code
May be it can be some library? idk
You have found the answer.
Whose theory? Not mine.
so the code doesn't work because the SD card hasn't sufficient powe when I add the GPS?
No, the device does not have sufficient power.
You have proven the SD code works.
ok thanks mate
Yes I did and all went good
When you add devices, verify you have sufficient power to operate them at their maximum value, plus 10%. Your GPS is a power-hungry device.
ok I will prove it
