Hello, I need help on connecting 3 leds (Im new :D)
I have all the cables correctly because i change the cable of the pin it works and viceversa.
int led1 = 12;
int led2 = 11;
int led3 = 10;
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
digitalWrite(led1, HIGH);
digitalWrite(led2, LOW);
digitalWrite(led3,LOW);
digitalWrite(led1, LOW);
digitalWrite(led2, HIGH);
digitalWrite(led2,LOW);
digitalWrite(led3,HIGH);
Which part do you need help with? You haven't explained your problem particularly well.
Welcome to the forum.
Can you explain what help you need?
Are you perhaps seeing the result of not having a delay() after the digitalWrite(led3,HIGH); so as soon as Led3 is switched on the code immediately jumps to the top of loop() and switches it off again?
Steve
