Hello i need help with my code
I am making a welding system with a Linear Rail Motion and I need the forward speed to be slower than the reverse speed. and aome limit swich the code I have does not do this to me . can any one help and fi this costs maney pls tell me how much it cost.
// defines pins numbers
const int stepPin = 5;
const int dirPin = 2;
const int enPin = 8;
const int LimitSwitch_LEFT_Pin  = 10;
const int LimitSwitch_RIGHT_Pin = 11;
  pinMode(LimitSwitch_LEFT_Pin , INPUT);
  pinMode(LimitSwitch_RIGHT_Pin , INPUT);
  // Sets the two pins as Outputs
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  pinMode(enPin,OUTPUT);
  digitalWrite(enPin,LOW);
  // Set Dir to Home switch
  digitalWrite(dirPin,HIGH); // Enables the motor to move in a particular direction
    int leftSw  = digitalRead( LimitSwitch_LEFT_Pin);
    int rightSw = digitalRead( LimitSwitch_RIGHT_Pin);
    if( (leftSw  == HIGH && (digitalRead(dirPin) == HIGH)) ||
        (rightSw == HIGH && (digitalRead(dirPin) == LOW)) ){
       motorStep(1);
    else if( leftSw == LOW && (digitalRead(dirPin) == HIGH) ){
          digitalWrite(dirPin,LOW);
          delay(50);
    else if( rightSw == LOW && (digitalRead(dirPin) == LOW ) ){
          delay(50);
void motorStep( int MAX){
   for(int x = 0; x < MAX; x++) {
        digitalWrite(stepPin,HIGH);
        delayMicroseconds(70);
        digitalWrite(stepPin,LOW);
Hello
take a look here.
The usage of a FSM for your project is strongly recommended.
hello im using TB6560 stepper driver and nema 23 stepper amd i need slove problem with code pls canu help me
Just read your dirPin and set the delay time accordingly....
void motorStep( int MAX) {
  int delayTime;
  if( digitalRead(dirPin) == HIGH) {
    delayTime = 70;
    delayTime = 140;
  for (int x = 0; x < MAX; x++) {
    digitalWrite(stepPin, HIGH);
    delayMicroseconds(delayTime);
    digitalWrite(stepPin, LOW);
$1,000,000 USD please :slight_smile:
