hello my code is not working could anyone help
hello i am new to arduino programming and i was trying to write a program that slowly increases then decreases the brightness of an led.
const int led = 11 ;
 pinMode(led, OUTPUT);
 int j = 3;
 while(j > 0)
 Serial.print(j);
 Serial.print(", ");
 j--;
 Serial.println("GO...\n");
 static int val = 5;
 static int dir = 1;
 val += 50 * dir ;
 val = a(val, dir) ;
 analogWrite(leds[0], val) ;
 delay (500) ;
 Serial.println(val);
int a (int val, int dir)
 if ((val == 255) || (val == 0))
 dir = dir * -1 ;
 if (dir < 0)
 Serial.println("Going Up");
 return dir ;
this is my code. can anyone show what i am doing wrong. im using an arduino uno
Thanks for posting in code tags.
What do you think this line does?
The array 'leds[]' has not even been declared anywhere in your program. The compile error messages probably told you that.
aarg:
i noticed that and changed it later (i also edited the code in the question)but it still didnt work
Good job using code tags with your first post.
Are you going to post the code so that we can see what you have done?
val = a(val, dir) ;
 delay (500) ;
What is your serial print showing?
The function a(val,dir) concludes with return dir what do you expect the values to be?
 dir = dir * -1 ;
 if (dir < 0)
 return dir ;
