Hello
This code is for managing Wi-Fi. And when ESP is not defined for Wi-Fi, it goes into hotspot mode and the web console is accessible with IP 192.168.4.1. And when you enter the console, you will see the list of Wi-Fi. But the scan part is not working properly, I want the Wi-Fi list to be refreshed when the scan button is pressed.
Thank you for your guidance.
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
//Variables
int i = 0;
int statusCode;
const char* ssid = "text";
const char* passphrase = "text";
String st;
String content;
//Function Decalration
bool testWifi(void);
void launchWeb(void);
void setupAP(void);
//Establishing Local server at port 80 whenever required
ESP8266WebServer server(80);
Serial.begin(115200); //Initialising if(DEBUG)Serial Monitor
Serial.println("Disconnecting previously connected WiFi");
WiFi.disconnect();
EEPROM.begin(512); //Initialasing EEPROM
delay(10);
pinMode(LED_BUILTIN, OUTPUT);
Serial.println("Startup");
//---------------------------------------- Read EEPROM for SSID and pass
Serial.println("Reading EEPROM ssid");
String esid;
for (int i = 0; i < 32; ++i)
esid += char(EEPROM.read(i));
Serial.print("SSID: ");
Serial.println(esid);
Serial.println("Reading EEPROM pass");
String epass = "";
for (int i = 32; i < 96; ++i)
epass += char(EEPROM.read(i));
Serial.print("PASS: ");
Serial.println(epass);
WiFi.begin(esid.c_str(), epass.c_str());
if (testWifi())
Serial.println("Succesfully Connected!!!");
return;
Serial.println("Turning the HotSpot On");
launchWeb();
setupAP();// Setup HotSpot
Serial.println("Waiting.");
while ((WiFi.status() != WL_CONNECTED))
Serial.print(".");
delay(100);
server.handleClient();
if ((WiFi.status() == WL_CONNECTED))
for (int i = 0; i < 10; i++)
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
//-------- Fuctions used for WiFi credentials saving and connecting to it which you do not need to change
bool testWifi(void)
int c = 0;
Serial.println("Waiting for Wifi to connect");
while ( c < 20 ) {
if (WiFi.status() == WL_CONNECTED)
return true;
Serial.print("*");
c++;
Serial.println("");
Serial.println("Connect timed out, opening AP");
return false;
void launchWeb()
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Local IP: ");
Serial.print("SoftAP IP: ");
Serial.println(WiFi.softAPIP());
createWebServer();
// Start the server
server.begin();
Serial.println("Server started");
void setupAP(void)
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0)
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
for (int i = 0; i < n; ++i)
// Print SSID and RSSI for each network found
Serial.print(i + 1);
Serial.print(": ");
Serial.print(WiFi.SSID(i));
Serial.print(" (");
Serial.print(WiFi.RSSI(i));
Serial.print(")");
Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE) ? " " : "*");
delay(10);
Serial.println("");
st = "<ol>";
st += "<li>";
st += WiFi.SSID(i);
st += " (";
st += WiFi.RSSI(i);
st += ")";
st += (WiFi.encryptionType(i) == ENC_TYPE_NONE) ? " " : "*";
st += "</li>";
st += "</ol>";
delay(100);
WiFi.softAP("how2electronics", "");
Serial.println("softap");
launchWeb();
Serial.println("over");
void createWebServer()
server.on("/", []() {
IPAddress ip = WiFi.softAPIP();
String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
content = "<!DOCTYPE HTML>\r\n<html>Hello from ESP8266 at ";
content += "<form action=\"/scan\" method=\"POST\"><input type=\"submit\" value=\"scan\"></form>";
content += ipStr;
content += "<p>";
content += st;
content += "</p><form method='get' action='setting'><label>SSID: </label><input name='ssid' length=32><input name='pass' length=64><input type='submit'></form>";
content += "</html>";
server.send(200, "text/html", content);
server.on("/scan", []() {
//setupAP();
content = "<!DOCTYPE HTML>\r\n<html>go back";
server.on("/setting", []() {
String qsid = server.arg("ssid");
String qpass = server.arg("pass");
if (qsid.length() > 0 && qpass.length() > 0) {
Serial.println("clearing eeprom");
for (int i = 0; i < 96; ++i) {
EEPROM.write(i, 0);
Serial.println(qsid);
Serial.println("");
Serial.println(qpass);
Serial.println("");
Serial.println("writing eeprom ssid:");
for (int i = 0; i < qsid.length(); ++i)
EEPROM.write(i, qsid[i]);
Serial.print("Wrote: ");
Serial.println(qsid[i]);
Serial.println("writing eeprom pass:");
for (int i = 0; i < qpass.length(); ++i)
EEPROM.write(32 + i, qpass[i]);
Serial.println(qpass[i]);
EEPROM.commit();
content = "{\"Success\":\"saved to eeprom... reset to boot into new wifi\"}";
statusCode = 200;
ESP.reset();
content = "{\"Error\":\"404 not found\"}";
statusCode = 404;
Serial.println("Sending 404");
server.sendHeader("Access-Control-Allow-Origin", "*");
server.send(statusCode, "application/json", content);
