Hello, Replacing comical RFID reader, new one made with Arduino Uno - returning different value
I am new to Arduino programming. We have an RFID reader, comical purchased with not sure high end encryption. The RFID example DumpInfo does read the cards "aptiQ 9520" , exempt return wrong values. I am sure my knowledge of the whole card reader topic is apparent. I have read about authentication key and other decrypting card key, i honestly have no clue. I maybe going down a rabbit hole, I have added to the following example "DumpInfo" to see if any thing would make sense from other articles. I believe the term for what i am doing is spoofing card to return correct key, to return the correct value.
 * Typical pin layout used:
 *             MFRC522      **Arduino**       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   **Uno/101**       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS      SDA(SS)      10            53        D10        10               10
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
 * More pin layouts for other boards can be found here: https://github.com/miguelbalboa/rfid#pin-layout
#include <SPI.h>
#include <MFRC522.h>
#include <SoftwareSerial.h>
#include <SimpleTimer.h>
#define RST_PIN         9          // Configurable, see typical pin layout above
#define SS_PIN          10         // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
// the timer object
SimpleTimer  HBtimer;
char tag[10];
int tagindex=0;
SoftwareSerial mySerial(2, 3); //pin3 Rx, pin2 Tx
byte readCard[]={0xFF,0x07,0x80,0xBC,0xFF,0xFF,0xFF,0xFF,0xFF};
int cardPresent=0;
int cardBytesRead;
int readComplete;
int CMD[64];
int comlen =0;
int out_flag =0;
boolean isReplyRead=0;
String strAuthResp;
String strTagID;
	Serial.begin(9600);		// Initialize serial communications with the PC
	while (!Serial);		// Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
	SPI.begin();			// Init SPI bus
	mfrc522.PCD_Init();		// Init MFRC522
	delay(4);				// Optional delay. Some board do need more time after init to be ready, see Readme
	mfrc522.PCD_DumpVersionToSerial();	// Show details of PCD - MFRC522 Card Reader details
	Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
  mySerial.begin(9600);
        cardBytesRead=0;
        readComplete=0;
  delay(50);
  mySerial.listen();
  delay(10);
oid loop() {
	// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
	if ( ! mfrc522.PICC_IsNewCardPresent()) {
		return;
	// Select one of the cards
	if ( ! mfrc522.PICC_ReadCardSerial()) {
		return;
 HBtimer.run();
    readComplete=0;
    cardPresent=digitalRead(5);
    cardPresent=!cardPresent;
    if((cardPresent)&&(!readComplete)){
    readCardF();
    delay(50);
	// Dump debug info about the card; PICC_HaltA() is automatically called
	mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
void readCardF(){
  mySerial.write(readCard, sizeof(readCard));
  while(mySerial.available()&&readComplete<1){
    byte C = mySerial.read();
    if (C<16) Serial.print("0");
    Serial.print(C,HEX);
    cardBytesRead++;
      if ((cardBytesRead>16)&&(cardBytesRead<9)){
        byte hinibble = (C >> 16) & 0x0f;
        byte lonibble = C & 0x0f;
        tag[tagindex++] = bintohexascii(hinibble);
        tag[tagindex++] = bintohexascii(lonibble);
      } //End If
  if (cardBytesRead==9) {
          tagindex=0;
          cardBytesRead=0;
          readComplete=1;
           Serial.println("");
     Serial.println("RFID tag value= ");
     Serial.println(tag);
           Serial.println("");
           strTagID=tag;
     isReplyRead=0;
     if(strTagID.length()==8){
              //Success
              //Call our HTTP GET function
              //For testing purposes we call the resetFunc here so we can re-scan to keep testing
              delay(100);
              resetFunc();
                Serial.println("Invalid Length of RFID Card");
                delay(100);
                resetFunc();
            return;
  }//End If carybytesread==9
  }//End While
} //End Function
char bintohexascii(byte x)
  char hex[16] = {
    '0', '1', '2', '3', '4', '5', '6', '7',
    '8', '9', 'A', 'B', 'C', 'D', 'E', 'F'
  return hex[x & 0x0f];
void resetFunc() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile ("  jmp 0");
Looking for away to run through different keys or what even you call, once the code hits Contains("954888") printed on the card is fragment of what is on the card , print the key for new Arduino RFID to return the same values as the old RFID reader - just example. I have no idea how to loop though different keys.
The next step you should do is using google translate.
Write down a much more detailed description of what you want to do in your
native language
and then let do googe translate the translation.
In such specific technical things each word added is worth gold.
Writing in english directly but with just a few words and poor words is not problem-solving it adds a new problem on top of the technical problem: a language problem.
or you look thorugh the language-subforums if there is a sub-forum in your native language
