Are you sure about that baud rate? Your picture looks like the one I have (SFE?) and I think the default was 38k (I don't have it with me). What happens with the blinking light? Does it change when you open the serial port on the PC?
I think your problem is in communicating from the Arduino to the BlueTooth module. The blinking going to solid means that the connection from the PC to the module was made successfully.
Are you powering the Arduino with the barrel jack or USB during the test? I am not sure, but I think you may get port contention if the USB is connected. I use a MEGA for a lot of testing so I have the extra ports and can use the main one for diagnostics. I know on Pro Minis where I have an xBee on the Serial connection I have to disconnect my xBee for FTDI to work and I think I have to disconnect FTDI for the xBee to work (I always do; I am not sure I ever tried leaving it connected).
One poster says you are right about default baud rate being 9600.
Another poster said HyperTerminal did not work for him and suggests an alternative. I use PuTTY for most of my testing.
EDIT - one more note: I don't have it in front of me, but the comment about shorting DTR to RTS lit up some synapses; I think I did that. I did serial data comm stuff decades ago and it is one of those things you just do without giving it much thought except for those rare occasions where flow control was really necessary. On many installations it was a big waste of wire as it was shorted on both ends to form a disconnected circle...
