Hello z80 with arduino
Can you please tell us your electronics, programming, arduino, hardware experience?
Looking at the Github for the shield, it looks as though you may have to load some code (supplied in the example) into the Z80 to get it to know what is happening around it. (I may be wrong)
Tom... :smiley: :+1: :coffee: :australia:
I think, the Mega stores the Z80 machine code and applies it to the Z80 pins via I/O pin sequences.
The schematic posted in post #6, goes with this Project Hub
The code in the Arduino Project Hub, is not the code that @younggoo is using.
The schematic that @younggoo has posted in post #6 needs this code I believe.
#include "memory.h"
/*Wiring:
Address Lines:
Arduino Pin 22..29   <--->   Z80 A0..A7
Data Lines:
Arduino Pin 49..42   <--->   Z80 D0..D7
Control lines:
 Arduino Pin 10  <--->  Z80 Pin 6 (CLK)
 Arduino Pin 19  <--->  Z80 Pin 21 (RD)
 Arduino Pin 18  <--->  Z80 Pin 22 (WR)
 Arduino Pin A9  <--->  Z80 Pin 19 (MREQ)
 Arduino Pin A10 <--->  Z80 Pin 20 (IORQ)
 Arduino Pin 40  <--->  Z80 PIN 26 (RESET)
//Working memory
uint8_t memory[1024];
//Z80 Out
//Port D
#define RD_PIN PD2 //(INT2 - Arduino Pin 19) Z80 Pin21
#define WR_PIN PD3 //(INT3 - Arduino Pin 18) Z80 Pin 22
#define RD    ((PIND & (1 << RD_PIN)) == 0)
#define WR    ((PIND & (1 << WR_PIN)) == 0)
#define PORT_MASK_D ~((1 << RD_PIN) + ( 1 << WR_PIN));
//Port K
#define MREQ_PIN PK1 //(PCINT17 - Arduino Pin A9) Z80 Pin 19
#define IORQ_PIN PK2 //(PCINT18 - Arduino Pin A10) Z80 Pin 20
#define MREQ  ((PINK & (1 << MREQ_PIN)) == 0)
#define IORQ  ((PINK & (1 << IORQ_PIN)) == 0)
#define ADDR PINA //A0..A7
#define ADDR_HI (PINC & (PC0 | PC1)) //A8..A9
//Z80 In
//PortB
#define CLK_PIN PB4 //(OC2A) Z80 Pin 6
//Port G
#define INT_PIN PG0 //Z80 Pin 16, Arduino Pin 41
#define RST_PIN PG1 //Z80 PIN 26, Arduino Pin 40
#define WAIT_PIN PG2 //Z80 Pin 24, Arduino Pin 39
#define RESET(b)  b == 0 ? PORTG |= (1 << RST_PIN) : PORTG &= ~(1 << RST_PIN);
#define PORT_MASK_G (1 << INT_PIN) + (1 << RST_PIN) + (1 << WAIT_PIN);
// the setup function runs once when you press reset or power the board
  const long fClk = 1E5;
  //Serial.begin(256000);
  DDRA = 0x00; //Port A (Addr Low) input
  DDRC = 0x00; //Port C (Addr Hi) input
  DDRD &= PORT_MASK_D;
  DDRK = 0x00; //Port K Input (Z80 sysctl out)
  DDRG |= PORT_MASK_G;
  PORTG |= PORT_MASK_G;
  DDRL = 0xff; //Data Bus
  PORTL = 0x00;
  //Pin Interrupts
  EICRA |= (1 << ISC31) + (0 << ISC30) + (1 << ISC21) + (0 << ISC20);
  EIMSK |= (1 << RD_PIN) + (1 << WR_PIN);
  //Clock Timer2
  DDRB |= (1 << CLK_PIN); //Output
  TCCR2A = (0 << COM2A1) + (1 << COM2A0); //Toggle OC2A on Compare Match
  TCCR2A |= (1 << WGM21); //CTC Mode
  TCCR2B = (0 << CS22) + (0 << CS21) + (1 << CS20); //No Prescaling
  OCR2A = 16E6 / (2 * fClk) - 1;
  memset(memory, 0, sizeof(memory));
  memcpy(memory, mem, sizeof(mem));
  RESET(1);
  delay(1);
  RESET(0);
// the loop is empty, because this is interrupt-driven
void loop() {}
//Read data from Data Bus
inline uint8_t DATA_GET() {
	DDRL = 0;
	return PINL;
//Write data to Data Bus
inline void DATA_PUT(uint8_t d) {
	DDRL = 0xff;
	PORTL = d;
ISR(INT2_vect) {//CPU Reads
  //Serial.println(ADDR);
  if (MREQ) {
    DATA_PUT(memory[ADDR]);
ISR(INT3_vect) {//CPU Writes
  if (MREQ) {
    memory[ADDR] = DATA_GET();
  else {//IORQ
    Serial.print((char)DATA_GET());
I may be wrong...
i do upload and wiring this code
but it don't wanna work
Does everything you do, happen without any mistakes? :slight_smile: Check and re-check your wiring. There isn't any other way.
Nobody here has a magic way to guess what you did wrong. The image you posted is just a mess of wires. You have to be there to trace every wire, it can't be done visually from such a rat's nest picture.
anyway thank you reply
