HELLP!!!
Hey, I would really need some help with code, I found it on the internet, and I tried it it works, but for some reason just for analog input 0 and 1, I tried to add the analog pins in the code, didn't help, please some one help. (BTW piezo drums)
unsigned char PadNote[16] = {47,18,32,38,43,13,45,17,21,36,0,44,0,19,0,21};
unsigned char status;
int PadCutOff[16] = {100,100,100,200,100,100,100,100,100,350,100,350,100,100,100,100};
int MaxPlayTime[16] = {25,25,25,25,25,25,25,25,25,40,25,40,25,25,25,25};
#define midichannel 0;
boolean activePad[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
int PinPlayTime[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
boolean VelocityFlag = true;
int analogPin[2] = {A0,A1};
int pin = 0;
int hitavg = 0;
int pad = 0;
int r0 = 0;
int r1 = 0;
int r2 = 0;
int count = 0;
int multiplex1[8];
int multiplex2[8];
// Setup
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
Serial.begin(115200); // connect to the serial port 115200
// Main Program
void loop(){
readSensors(0);
readSensors(1);
checkSensors(0);
checkSensors(1);
void readSensors (int analogPin) {
for(count=0; count <= 7; count++)
r2 = bitRead(count,0);
r1 = bitRead(count,1);
r0 = bitRead(count,2);
digitalWrite(2, r0);
digitalWrite(3, r1);
digitalWrite(4, r2);
if(analogPin==0) {
multiplex1[count] = analogRead(analogPin);
else if(analogPin==1) {
multiplex2[count] = analogRead(analogPin);
void checkSensors (int analogPin) {
for(int pin=0; pin <=7; pin++) {
if(analogPin==0) {
hitavg = multiplex1[pin];
pad=pin;
hitavg = multiplex2[pin];
pad=pin+8;
if((hitavg > PadCutOff[pad])) {
if((activePad[pad] == false)) {
if(VelocityFlag == true) {
hitavg = (hitavg / 8) -1;
else {
hitavg = 127;
MIDI_TX(144,PadNote[pad],hitavg);
PinPlayTime[pad] = 0;
activePad[pad] = true;
else {
PinPlayTime[pad] = PinPlayTime[pad] + 1;
else if((activePad[pad] == true)) {
if(PinPlayTime[pad] > MaxPlayTime[pad]) {
activePad[pad] = false;
MIDI_TX(128,PadNote[pad],0);
void MIDI_TX(unsigned char MESSAGE, unsigned char PITCH, unsigned char VELOCITY) {
status = MESSAGE + midichannel;
Serial.write(status);
Serial.write(PITCH);
Serial.write(VELOCITY);
 if(analogPin==0) {
Could it be some thing to do with code only being designed to use analogue pins 0 and 1?
Please always use code tags when posting code.
This is a big clue
well I copied it so there was no titels, and don't worry i'm not that dense I tried to add other pins, but they just dont respond, and also i'm not familier with midi programing, sorry and thanks.
plz some one help me with this code, I dont know hot to make to work wit 6 analoh inputs.... please
So, post that code, explain what it did that you didn't expect, and what it didn't do that you did expect.
That way, we can help you.
I tried to add other pins, but the problem is that the midi notes are sent just from pin A0 and A1, and I dont understand how to expand
Please see reply #5
Unfortunetly in complete anger and desperation I didnt save it... :confused:
inhost:
Bit convenient. But you know what you did so try it again and post the results.
I have noticed a few questions about piezo drumpads at the moment - there must be a school assignment on!
No not really, Im a college student, but my speciality is electrical enginering, and saldy its just for fun, I'm not even a musician, my only programming expierience is about a month, with a plc and trying to figure out a BMS, and its my final work so, if its not to hard please help me with this, its just form my own amusment, and just tu expierience the fun of drums... I know its sounds pathetic, but thats how it is :slight_smile:
How is it both "my final work" and also "just form my own amusment"?
I would strongly suggest you choose a better subject line next time.
Homework is not a forbidden subject here. We're happy to help, but not to do it for you.
You should have read "How to use this forum", a sticky-topic at the top of the list on every area hear. Especially see tip number 6:
http://forum.arduino.cc/index.php/topic,148850.0.html
My final work is BMS (building manigment systems) and Im just trying to understand midi for my own intrests, thank you for your replays :slight_smile:
