Hello everyone, I am in the process of carrying out an aeronautical project concerning an EFIS for Microlight and I am experiencing some difficulties in making an AHRS Yost Labs 3-Space Nano Carrier Board interact with the serial output of the Arduino Mega 2560.
I just need to recover the Pitch Roll and Heading ...
I have consulted the User Manual over and over again and I am slightly dumped, if someone has an example to provide me I am interested.
Is EFIS43.ino someone else's sketch, unmodified? That you want to modify to add this sensor? If you have absolutely no idea where to begin, you should post in the Gigs and Collaborations forum. I did look at the sensor user manual, it does describe the protocols quite well. But the huge extent of the code will mean that nobody will want to do this for free, unless you can do 99% of it, and only have minor problems.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
I see you also posted this in the Français board: https://forum.arduino.cc/index.php?topic=671893
I'm not going to merge the threads since they are in different languages, but be aware that posting the same thing in two different languages is still cross-posting.
