So i've been working on this project for most of the day. Quick run down of my project. I've got a bunch of sensors and one 2X16LCD display. I already got it to display a simple message earlier, so no problem getting it to display.
So the problem. In the main loop function i'm continuously getting data from the sensors, but i only have one small lcd to display it on, so i need for the screen to display data as alternating screens or as a scrolling message that pans over the data so that all the data can be read off it. I would also prefer not using millis() function since I've read that it overflows after 50 days and messes everything up. I may also be getting a real time clock (RTC) on thursday so i may use that if i figure out to use it at all. Any suggestions would be great, i'm just going to post my code currently
created by John Chabot
arduino control system for hydroponic design project
// include the library code:
#include <LiquidCrystal.h>
#include <Time.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int lightSensor1 = A0; //analog input port for light sensor 1
const int lightSensor2 = A1; //analog input port for light sensor 2
const int lightSensor3 = A2; //analog input port for light sensor 3
const int lightSensor4 = A3; //analog input port for light sesnor 4
const int phSensor1 = A4; //analog ph sensor input port
const int phSensor2 = A5; //analog ph sensor input port
const int phSensor3 = A6; //analog ph sensor input port
const int phSensor4 = A7; //analog ph sensor input port
const int led1 = 6; // digital pin to activate pump 1
const int led2 = 7; // digital pin to activate pump 2
const int led3 = 8; // digital pin to activate pump 3
const int led4 = 9; // digital pin to activate pump 4
const int maxLight = 800; // Light Value under direct Sunlight
const int minLight = 0; // Light Value when photocell is covered
const int numReading = 10; //number of reading for data smoothing
//variables for turning on section of code in the loop if they are connected
int on1 = 0;
int on2 = 0;
int on3 = 0;
int on4 = 0;
//variables to writing values coming off the light sensors
int lightValue1 = 0;
int lightValue2 = 0;
int lightValue3 = 0;
int lightValue4 = 0;
//variables to writing values coming off the ph sensors
int phValue1 = 0;
int phValue2 = 0;
int phValue3 = 0;
int phValue4 = 0;
//array used for smoothing data from light sensor
int array1[10];
int array2[10];
int array3[10];
int array4[10];
//variables to storing smoothed averages
int avgValue1 = 0;
int avgValue2 = 0;
int avgValue3 = 0;
int avgValue4 = 0;
int currentIndex = 0; //store current loop position
const int lightOnPin = 13; //digital pin location for lightOn switch
int lightOn = 0; //store current loop position
const int autoSwitchPin = 14; //digital pin locatoin for autoSwitch switch
int autoSwitch = 0; //store current loop position
const int manStatePin = 15; //digital pin locatin for manSwitch switch
int manState = 0; //store current loop position
int setupTime = 60000; //allow for 1 minutes to check for light sensors
lcd.begin(16, 2); //activate lcd
// Uses this loop to ensure that modules are attached, actives code in the loop section accordingly
lcd.print("Intializing ");
lcd.setCursor(0,1);
lcd.print("Please Wait ");
// while loop to detect which which modules are connected
while (millis() < setupTime){
//current light reading
int lightValue1 = analogRead(lightSensor1);
int lightValue2 = analogRead(lightSensor2);
int lightValue3 = analogRead(lightSensor3);
int lightValue4 = analogRead(lightSensor4);
if(lightValue1 != minLight){
on1 = 1;
pinMode(led1, OUTPUT); //sets pin as output (activates)
clearScreen(); //calls clearScreen function to erase lcd
//tells users unit detected the resets screen
lcd.print("detected unit 1 ");
lcd.setCursor(0,0);
lcd.setCursor(0,1);
setupTime = setupTime + 1000;
if(lightValue2 != minLight){
on2 = 1;
pinMode(led2, OUTPUT); //sets pin 7 to output for pump2
clearScreen();
lcd.print("detected unit 2 ");
lcd.setCursor(0,0);
lcd.setCursor(0,1);
if(lightValue3 != minLight){
on3 = 1;
pinMode(led3, OUTPUT); //sets pin 8 to output for pump3
clearScreen();
lcd.print("detected unit 3 ");
lcd.setCursor(0,0);
lcd.setCursor(0,1);
if(lightValue4 != minLight){
on4 = 1;
pinMode(led4, OUTPUT); //sets pin 9 to output for pump4
clearScreen();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
clearScreen();
//read digital pin state to determin state of control switches
lightOn = digitalRead(lightOnPin);
autoSwitch = digitalRead(autoSwitchPin);
manState = digitalRead(manStatePin);
//increments counter for data smoothing
currentIndex++;
if(on1 == 1){ // code only active if detected in setup function
phValue1 = map(analogRead(phSensor1),0, 1023, 0, 14); //reads current light value from photocell
//maps light from analog input to 0 to 100 scale
int adjustedLightValue1 = map(lightValue1, 0, 800, 0, 100);
//creats updates array for data smoothing
array1[currentIndex] = adjustedLightValue1;
avgValue1 = smoothAvg(array1);
//logic tree for light controls
if(lightOn == 1){
if(autoSwitch == 1){
setLightLevelAuto(avgValue1, led1);
else{
setLightLevelMan(led1);
if(on2 == 1){
phValue2 = map(analogRead(phSensor2),0, 1023, 0, 14);
int adjustedLightValue2 = map(lightValue2, 0, 800, 0, 100);
array2[currentIndex] = adjustedLightValue2;
avgValue2 = smoothAvg(array2);
if(lightOn == 1){
setLightLevelAuto(avgValue2, led2);
else{
setLightLevelMan(led2);
if(on3 == 1){
phValue3 = map(analogRead(phSensor3),0, 1023, 0, 14);
int adjustedLightValue3 = map(lightValue3, 0, 800, 0, 100);
array3[currentIndex] = adjustedLightValue3;
avgValue3 = smoothAvg(array3);
if(lightOn == 1){
setLightLevelAuto(avgValue3, led3);
else{
setLightLevelMan(led3);
if(on4 == 1){
phValue4 = map(analogRead(phSensor4),0, 1023, 0, 14);
int adjustedLightValue4 = map(lightValue4, 0, 800, 0, 100);
array4[currentIndex] = adjustedLightValue4;
avgValue4 = smoothAvg(array4);
if(lightOn == 1){
else{
//resets currentIndex if it advances 10 positions
if(currentIndex > numReading -1){
currentIndex = 0;
//function for clearing lcd display
void clearScreen(){
lcd.setCursor(0,0);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,0);
//averages array
int smoothAvg(int array[]){
int total = 0;
for (int n = 0; n < 10; n++){
total = total + array[n];
int average = total/10;
return average;
//control logic for auto light mode
void setLightLevelAuto(int lightLevel, int pin){
if(lightLevel > 60)
digitalWrite(pin, LOW);
else if(lightLevel < 61 && lightLevel > 29)
int fade = map(lightLevel, 30, 60, 0, 255);
analogWrite(pin, fade);
else(lightLevel < 30);
digitalWrite(pin, HIGH);
//control logic for man light mode
void setLightLevelMan(int pin){
if (manState == 1)
analogWrite(pin, 100);
