Help! Actuator making NOISEE
Hey guys,
I need some help because I’m at my wits end.
Arduino UNO running two actuators (DC Motor and Servo Motor) controlled by sensors.
I can manipulate my flex sensor to drive Servo Motor without ANY cross-talk or noise issues.
However, when I manipulate my soft pot to drive the DC Motor, it drives the DC Motor mostly fine but causes a mess on the rest of the board. (ex - causing my Servo to go haywire)
I first need to isolate whether it’s a coding error, or a breadboard/wiring error. I understand you can’t look over my wiring but I have a thousand times and feel 98% confident it’s correct.
I’m hoping someone would be nice enough to look at my code and tell me if that’s the problem!
_4_29_2015_MPU_FINAL.ino (1.42 KB)
How are you driving the motor (thinks - your using motor shield with PWM and servo)
Mark
Do you have a diode in place across the motor to clamp the back EMF? If not, you need that.
You may also need additional caps to stablize the power supply.
I think the problem is almost certainly with the wiring - motors and other inductive loads are trickier to wire.
@DrA - the Servo lib and pwm ues the same timer.
Mark
Yes I do have a diode to prevent fly-back. My goal was to see if anyone could point out any coding issues. At this point I’m going to rip everything out and re-wire. Thanks
You will have more people looking at you code if you post it in code tags. There are reasons why people will not download code.
Can you please post a copy of your sketch, using code tags?
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
What is the spec of the servo and the actuator and in the circuit can you show how and what is powering them.
Thanks. Hope to help......Tom.... :slight_smile:
