help adding 2 sketches together
hi all
i have 2 sketches and i want then both to run together one after the other but i’m new to arduino so need help and instructions on how to compile the 2 together if i add the second to the bottom of the other i get
redefinition of void setup so i know i’m doing something wron but dont know what
first sketch
// FILE: lightning.pde
// AUTHOR: Rob Tillaart
// DATE: 2012-05-08
// PUPROSE: simulate lighning POC
#define BETWEEN 2579
#define DURATION 43
#define TIMES 7
#define LEDPIN 13
unsigned long lastTime = 0;
int waitTime = 0;
Serial.println(“lightning 0.0”);
pinMode(LEDPIN, OUTPUT);
if (millis() - waitTime > lastTime) // time for a new flash
// adjust timing params
lastTime += waitTime;
waitTime = random(BETWEEN);
for (int i=0; i< random(TIMES); i++)
Serial.println(millis());
digitalWrite(LEDPIN, HIGH);
delay(20 + random(DURATION));
digitalWrite(LEDPIN, LOW);
delay(10);
// do other stuff here
second sketch
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 9;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(150); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
delay(5000); // wait for a second
I would start like this. Pick one sketch and make a copy of it, say called lightning2. Then I would look at your other sketch and start adding the relevant parts. Add all you variables and what the sketch actually does.
You do not need to add void setup() { } or void loop(){ }, just the relevant parts inside.
Good luck.
