Help adding an extra motor to an obstacle avoiding robot
Hi I am a beginner to programming and working with Arduino. Currently I’m doing an obstacle avoiding robot that also cleans floor. I have taken the arrangement done by instructables circuits since I have all the materials they used accessible (Arduino Uno, 3V DC motor, L298N motor driver), but I want to add an extra DC motor that will spin a sponge to make it a floor cleaning robot. But I can’t figure how to connect it and how to add it to the code. Also, will the L298N motor driver work or should I get something else?
Here is the code:
#include <Servo.h>          //Servo motor library. This is standard library
#include <NewPing.h>        //Ultrasonic sensor function library. You must install this library
//our L298N control pins
const int LeftMotorForward = 7;
const int LeftMotorBackward = 6;
const int RightMotorForward = 4;
const int RightMotorBackward = 5;
//sensor pins
#define trig_pin A1 //analog input 1
#define echo_pin A2 //analog input 2
#define maximum_distance 200
boolean goesForward = false;
int distance = 100;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function
Servo servo_motor; //our servo name
void setup(){
  pinMode(RightMotorForward, OUTPUT);
  pinMode(LeftMotorForward, OUTPUT);
  pinMode(LeftMotorBackward, OUTPUT);
  pinMode(RightMotorBackward, OUTPUT);
  servo_motor.attach(10); //our servo pin
  servo_motor.write(115);
  delay(2000);
  distance = readPing();
  delay(100);
  delay(100);
  delay(100);
  delay(100);
void loop(){
  int distanceRight = 0;
  int distanceLeft = 0;
  delay(50);
  if (distance <= 20){
    moveStop();
    delay(300);
    moveBackward();
    delay(400);
    moveStop();
    delay(300);
    distanceRight = lookRight();
    delay(300);
    distanceLeft = lookLeft();
    delay(300);
    if (distance >= distanceLeft){
      turnRight();
      moveStop();
    else{
      turnLeft();
      moveStop();
  else{
    moveForward();
int lookRight(){
  servo_motor.write(50);
  int distance = readPing();
  delay(100);
  return distance;
int lookLeft(){
  servo_motor.write(170);
  delay(100);
  return distance;
  delay(100);
int readPing(){
  delay(70);
  int cm = sonar.ping_cm();
  if (cm==0){
    cm=250;
  return cm;
void moveStop(){
  digitalWrite(RightMotorForward, LOW);
  digitalWrite(LeftMotorForward, LOW);
  digitalWrite(RightMotorBackward, LOW);
  digitalWrite(LeftMotorBackward, LOW);
void moveForward(){
  if(!goesForward){
    goesForward=true;
    digitalWrite(LeftMotorForward, HIGH);
    digitalWrite(RightMotorForward, HIGH);
void moveBackward(){
  goesForward=false;
  digitalWrite(LeftMotorBackward, HIGH);
  digitalWrite(RightMotorBackward, HIGH);
void turnRight(){
void turnLeft(){
Any help is much appreciated and sorry for the long post.
First of all get yourself a decent power source, as a 9V battery is not suited for this. A pair of LiPo batteries would do a lot better.
Secondly, consider getting a halfway modern H-bridge instead of the ancient L298 or its family members and it's 3-4V losses just on the chip itself - meaning a 3V motor needs a 6-7V power supply and half the power is lost in the driver.
Then for your sponge motor, if it has to run in one direction only just connect it with a MOSFET driver (use a logic level one, e.g. IRLZ44N or IRL540). A quick Google search will give you schematic examples.
First of all, thank you for answering. I did a google search for halfway modern H bridge but I am still confused as of what it is. Beside the things mentioned I have a Lafvin Super Starter Kit for UNO R3 that brings an Dual H Bdrige (L239D), would that work?
Anything MOSFET based. DRV8825, DRV8833, TB6612FNG. Just to name a few. About 0.5 Ohm on resistance, instead of a 3-4V drop.
The TB6612FNG runs cool at over 1A between two motors without heat sink. Don’t try that with the L298N.
