Help Arduino DC Motors linked to levers to send Serial port a position
Hello,
I face a problem using 3 DC motors connected mechanically to 3 levers. My code (see below) is correct but I can't find a solution to send the last position of each lever (angular position). In fact, I detect which of the 3 levers has moved and then I want to send a letter corresponding to the motor which has moved (F, G or H) with the last position at the end of the movement of the lever. Currently, I send various positions with a delay of 200ms (the positions during the movement of the lever), could you modify my code to get the letter and the last position of the lever ? Or a strategy to detect that the lever has finished its movement. I have tried different strategies but without success.
// Libraries
#include <AFMotor.h>
// Motor object
AF_DCMotor motor1(1);  // Assuming you have connected the motor 1 to motor port 1
AF_DCMotor motor2(2);  // Assuming you have connected the motor 2 to motor port 2
AF_DCMotor motor3(3);  // Assuming you have connected the motor 3 to motor port 3
// Potentiometer pin
const int potPinM1 = A0;
const int potPinM2 = A1;
const int potPinM3 = A2;
// Variables
//int potValue;
int potValueM1;
int potValueM2;
int potValueM3;
int potValueM4;
int potValueM1_init;
int potValueM2_init;
int potValueM3_init;
int potValueM4_init;
int prevMotor1Position = 10000; //10000 never reached
int prevMotor2Position = 10000; //10000 never reached
int prevMotor3Position = 10000; //10000 never reached
int targetPosition1;
int targetPosition2;
int targetPosition3;
int targetPosition4;
int currentPosition1;
int currentPosition2;
int currentPosition3;
int currentPosition4;
int threshold=0;
int MatLabMode;
  // Initialize serial communication
  // Set initial target position and current position
  targetPosition1 = 40;
  targetPosition2 = 40;
  targetPosition3 = 40;
  potValueM1 = 0;
  potValueM2 = 0;
  potValueM3 = 0;
  potValueM1_init = analogRead(potPinM1);
  potValueM2_init = analogRead(potPinM2);
  potValueM3_init = analogRead(potPinM3);
  // Set up motor driver
  motor1.setSpeed(255);  // Set a constant maximum speed for the motor 1
  motor2.setSpeed(255);  // Set a constant maximum speed for the motor 2
  motor3.setSpeed(255);  // Set a constant maximum speed for the motor 3
  // Set up potentiometer pin as input
  pinMode(potPinM1,INPUT);
  pinMode(potPinM2,INPUT);
  pinMode(potPinM3,INPUT);
  // Read potentiometer value (feedback)
  potValueM1 = analogRead(potPinM1);
  potValueM2 = analogRead(potPinM2);
  potValueM3 = analogRead(potPinM3);
  // Map potentiometer value to target position (0-180)
  currentPosition1 = map(potValueM1, 0, 1023, 0, 180);
  currentPosition2 = map(potValueM2, 0, 1023, 0, 180);
  currentPosition3 = map(potValueM3, 0, 1023, 0, 180);
  if (Mode == 1 ) // Master Level to move manually the 3 levers
    targetPosition1 = currentPosition1 ;
    targetPosition2 = currentPosition2 ;
    targetPosition3 = currentPosition3 ;
  if (Mode == 2 ) // Lever 1 master
   if (Mode == 3 ) // Lever 2 master
   if (Mode == 4 ) // Lever 3 master
      // Calculate the difference between current and target positions
  int positionError1 = targetPosition1 - currentPosition1;
  int positionError2 = targetPosition2 - currentPosition2;
  int positionError3 = targetPosition3 - currentPosition3;
    // Check the difference between the previous and current positions to detect movement
  int motor1Difference = abs(currentPosition1 - prevMotor1Position);
  int motor2Difference = abs(currentPosition2 - prevMotor2Position);
  int motor3Difference = abs(currentPosition3 - prevMotor3Position);
  // Determine the motor direction based on the position error
  if (positionError1 > threshold) {
    motor1.run(FORWARD);
  } else if (positionError1 < -threshold) {
    motor1.run(BACKWARD);
    motor1.run(RELEASE);
  if (positionError2 > threshold) {
    motor2.run(FORWARD);
  } else if (positionError2 < -threshold) {
    motor2.run(BACKWARD);
    motor2.run(RELEASE);
  if (positionError3 > threshold) {
    motor3.run(FORWARD);
  } else if (positionError3 < -threshold) {
    motor3.run(BACKWARD);
    motor3.run(RELEASE);
  if (Mode == 1) // Master level
    if ((prevMotor1Position != 10000) && (motor1Difference > 2))
        Serial.print("F,");
        Serial.println(currentPosition1);
        delay(200);
    if ((prevMotor2Position != 10000) && (motor2Difference > 2))
        Serial.print("G,");
        Serial.println(currentPosition2);
        delay(200);
    if ((prevMotor3Position != 10000) && (motor3Difference > 2))
        Serial.print("H,");
        Serial.println(currentPosition3);
        delay(200);
    prevMotor1Position = currentPosition1;
    prevMotor2Position = currentPosition2;
    prevMotor3Position = currentPosition3;
  // Add a delay if needed
  delay(20);  // Adjust the delay time as necessary
Welcome to the forum
Each time you read the position compare it with the previous position. If it has not changed then the lever has not moved
Thank you, yes I compare the current position with the previous position in the variables motor1Difference, motor2Difference and motor3Difference. I use it to detect a movement on one of the 3 levers. But how could I modify my code to compare the previous and the current value telling that when motor1difference = 0 Arduino has to send the position. To sum up , I detect a movement using motor1difference > 2 (threshold to be sure that lever has moved), and I want to get the final position when motor1difference = 0
if (abs(currentPosition - previousPosition) == 0)
  //do what you need when the lever has not moved
  previousPosition = currentPosition;  //remember the position for the next check
Ok but I want to send the position only if the lever has been moved before and at the end of the movement. How can I merge the detection and the condition (abs(currentPosition - previousPosition) == 0) ? Do I have to add a flag in the detection part to say that the lever has moved and how could I program it ?
Declare a boolean variable and use it to flag whether the lever moved last time you checked
Something like this
static bool movedLastTime = true;
if (abs(currentPosition - previousPosition) == 0 && movedLastTime == true)
    movedLastTime = false;
    previousPosition = currentPosition;  //remember the position for the next checke
