Help Arduino Mega 2560 + 3.2" TFT LCD
HazardsMind:
You shouldn't have to divide anything by 5.5, if the screen / touch ratio is correct, the code will already do it for you.
I found it
// UTouchCD.h
// Since there are slight deviations in all touch screens you should run a
// calibration on your display module. Run the UTouch_Calibration sketch
// that came with this library and follow the on-screen instructions to
// update this file.
// Remember that is you have multiple display modules they will probably
// require different calibration data so you should run the calibration
// every time you switch to another module.
// You can, of course, store calibration data for all your modules here
// and comment out the ones you dont need at the moment.
// These calibration settings works with my ITDB02-3.2S.
// They MIGHT work on your display module, but you should run the
// calibration sketch anyway.
#define CAL_X 0x00378F66UL
#define CAL_Y 0x03C34155UL
#define CAL_S 0x000EF13FUL
But i don't know the CAL_X CAL_Y correct
