I need a help witch this project.
in the void loop() : the 3rd if remove_int and else if remove_int doesn't work with lcd_standby() and lcd_remove() function.
I will be glad if you help me. thx
Edit : I deleted unnecessary codes because it was limited to 9000 words. If necessary, the full code: Full Code (click to see it)
#include "HUSKYLENS.h"
#include "SoftwareSerial.h"
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#define echopin 22 //distnce sensor
#define trigpin 23 //distance sensor
int time0; //time integer (hc-sr04)
int distance; //distance integer (hc-sr04)
int left1 = 2; //motor driver pins
int left2 = 3; //motor driver pins
int right1 = 4; //motor driver pins
int right2 = 5; //motor driver pins
int pwmleft = 6; //motor driver pins (pwm)
int pwmright = 7; //motor driver pins (pwm)
int RST_PIN = 49; // 50miso 51mosi 52sck (rfid)
int SS_PIN = 53; //(rfid)
int total = 0; //basket total
int water = 2; //tl
int chips = 6; //tl
int milk = 8; //tl
int yoghurt = 10; //tl
int remove_button = A1; //remove push button pin
int data ; //data receive from bluetooth
int auto_switch = A2; //auto-manuel drive switch pin
HUSKYLENS huskylens;
SoftwareSerial mySerial(10, 11); //rx tx (arduino) cam pins
LiquidCrystal_I2C lcd(0x27, 20, 4); //20x4 LCD define.
MFRC522 rfid(SS_PIN, RST_PIN); //rfid defined pins.
void printResult(HUSKYLENSResult result);
mySerial.begin(9600);
SPI.begin();
rfid.PCD_Init();
lcd_start();
total = 0;
pinMode(left1, OUTPUT);
pinMode(left2, OUTPUT);
pinMode(right1, OUTPUT);
pinMode(right2, OUTPUT);
pinMode(pwmleft, OUTPUT);
pinMode(pwmright, OUTPUT);
pinMode(echopin, INPUT);
pinMode(trigpin, OUTPUT);
pinMode(remove_button, INPUT_PULLUP);
pinMode(auto_switch, INPUT_PULLUP);
while (!huskylens.begin(mySerial))
delay(100);
digitalWrite(trigpin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigpin, LOW);
time0 = pulseIn(echopin, HIGH);
distance = (time0 / 2) / 29.1 ;
int remove_int = analogRead(remove_button);
int auto_int = analogRead(auto_switch);
if (Serial.available()) {
data = Serial.read();
if (auto_int <= 150) { //auto
while (huskylens.available())
HUSKYLENSResult result = huskylens.read();
printResult(result);
driveBot(result);
else if (auto_int >= 950) { // manuel
if (data == '1' && distance >= 30) { //forward
else if (data == '2' && distance >= 30) { //left
else if (data == '3' && distance >= 30) { //right
else if (data == '4') { //backward
else if (data == '0') { //stop
else {
if (remove_int >= 950) {
lcd_standby();
if ( ! rfid.PICC_IsNewCardPresent())
return;
if ( ! rfid.PICC_ReadCardSerial())
return;
if (rfid.uid.uidByte[0] == 186 ) {
else if (rfid.uid.uidByte[0] == 178 ) {
else if (rfid.uid.uidByte[0] == 217 ) {
else if (rfid.uid.uidByte[0] == 153 ) {
else {
undefined();
rfid.PICC_HaltA();
else if (remove_int <= 150) {
lcd_remove();
return;
return;
if (rfid.uid.uidByte[0] == 186 ) { //bu mekanın lordları bizi madafaka
else {
undefined();
rfid.PICC_HaltA();
void printResult(HUSKYLENSResult result) {
void driveBot(HUSKYLENSResult result) //auto
if (result.xCenter <= 120) //left
if ( distance >= 30) {
else {
else if (result.xCenter >= 200) //right
else {
else if ((result.xCenter >= 120) && (result.xCenter <= 200))
if (result.width <= 50 && distance >= 30) //forward
else if (result.width > 50 || distance < 30) // stop
else {
else {
void lcd_remove() {
lcd.setCursor(2, 0);
lcd.print("Plaese read the");
lcd.setCursor(0, 1);
lcd.print("Product for Removing");
lcd.setCursor(4, 2);
lcd.print("from Basket");
lcd.clear();
/*lcd.print("Basket Total");
lcd.setCursor(8,2);
lcd.print(total);
lcd.setCursor(11,2);
lcd.print("TL"); */
void lcd_standby() {
lcd.setCursor(6, 1);
lcd.print("Product");
lcd.setCursor(1, 3);
lcd.print("Basket Total=");
lcd.setCursor(14, 3);
lcd.print(total);
lcd.setCursor(18, 3);
lcd.print("TL");
lcd.clear();
sad.ino (11.7 KB)
