HELP!- Arduino Micro don't work with OLED 0.96'' Why?
Starting code of CrazyVito1. - Album on Imgur I've do it and the red led's of the arduino had blinked, then i've tryied with the code of the OLED and nothing goes on working on the screen nor nothing appears on it.
CrazyVito11:
Try running this sketch with the display connected, if it detects anything you know you have connected the display correctly (as long as no other device is on the I2C bus)
// I2C Scanner
// Written by Nick Gammon
// Date: 20th April 2011
#include <Wire.h>
  Serial.begin (9600);
// Leonardo: wait for serial port to connect
  while (!Serial)
Serial.println ();
  Serial.println ("I2C scanner. Scanning ...");
  byte count = 0;
  Wire.begin();
  for (byte i = 8; i < 120; i++)
    Wire.beginTransmission (i);
    if (Wire.endTransmission () == 0)
      Serial.print ("Found address: ");
      Serial.print (i, DEC);
      Serial.print (" (0x");
      Serial.print (i, HEX);
      Serial.println (")");
      count++;
      delay (1);  // maybe unneeded?
      } // end of good response
  } // end of for loop
  Serial.println ("Done.");
  Serial.print ("Found ");
  Serial.print (count, DEC);
  Serial.println (" device(s).");
}  // end of setup
void loop() {}
