farriz
June 15, 2022, 4:33pm
1
i want to make wireless smoke & temp detector using nrf24l01. it fine at transmitter but not fine in receiver. Sometimes it displays duplicate readings at LCD receiver making the wrong position for the reading value.
here is the video for LCD Display:
this is the code we have so far:
//Transmitter
#include <SPI.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
int gasvalue;
float tempvalue;
float vout;
LiquidCrystal_I2C lcd(0x27 ,20, 4);
pinMode(A0,INPUT);
pinMode(A1,INPUT);
pinMode(2,OUTPUT);
digitalWrite(2,HIGH);
Serial.println("Library initialization; EC/CSN pin and channel definition and module transmission and reception address definition");
delay(2000);
Mirf.cePin = 9;
Mirf.csnPin = 10;
Mirf.spi = &MirfHardwareSpi;
Mirf.init();
Mirf.channel = 1;
Mirf.payload = sizeof(float);
Mirf.config();
Mirf.setRADDR((byte *) "nrf01");
//TEMP SENSOR
vout=analogRead(A1);
vout=(vout*500)/1023;
tempvalue=vout;
Serial.println(tempvalue);
//GAS SENSOR
int analogSensor =analogRead(A0);
float gasvalue = (analogSensor-50)/10;
Serial.println(gasvalue);
if (gasvalue >= 10)
digitalWrite(2,LOW);
Mirf.setTADDR((byte *) "nrf02");
Mirf.send((byte *) &tempvalue); //TEMP SENSOR
while(Mirf.isSending());
Mirf.send((byte *) &gasvalue); //GAS SENSOR
//Receiver
#include <SPI.h>
#include <Mirf.h>
LiquidCrystal_I2C lcd(0x27,20,4);
int buzzer = 7;
float gasvalue;
float tempvalue;
pinMode(buzzer, OUTPUT);
lcd.init();
lcd.backlight();
delay(5000);
lcd.clear();
Mirf.cePin = 9;
Mirf.csnPin = 10;
Mirf.init();
Mirf.channel = 1;
Mirf.setRADDR((byte *) "nrf02");
Mirf.config();
Serial.println("Reception of the value :");
while(!Mirf.dataReady()){
//GAS SENSOR
Mirf.getData((byte *) &gasvalue);
lcd.setCursor(0,1);
lcd.print("GAS LEVEL: ");
lcd.print(gasvalue);
lcd.print("%");
//TEMP SENSOR
Mirf.getData((byte *) &tempvalue);
lcd.setCursor(0,0);
lcd.print("TEMPERATURE: ");
lcd.print(tempvalue);
lcd.print((char)223);
lcd.print("C ");
if (gasvalue >= 10)
lcd.setCursor(0,3);
lcd.print("DANGER");
lcd.setCursor(0,2);
lcd.print("-------FAN ON-------");
tone(buzzer, 1000, 10000);
lcd.setCursor(0,3);
lcd.print("NORMAL");
lcd.setCursor(0,2);
lcd.print("------FAN OFF-------");
noTone(buzzer);
lcd.clear();
Welcome to the forum
The receiver has no way of knowing what data is being received. Why not put all of the data to be transmitted into a struct and send it all at once then at the receiver end you will know what is being received
farriz
June 15, 2022, 4:55pm
3
so, where i need to change for coding? at transmitter or receiver?
Both
In the Tx put the data into a struct and send it
In the Rx read the struct and use the data
farriz
June 15, 2022, 5:22pm
5
it is correct? because it still display duplicate reading value at start only every time i on off, after that it ok. That make some noise at start because i connect with buzzer.
//Transmitter
#include <SPI.h>
#include <Mirf.h>
int gasvalue;
float tempvalue;
float vout;
pinMode(A0,INPUT);
pinMode(A1,INPUT);
pinMode(2,OUTPUT);
delay(2000);
Mirf.cePin = 9;
Mirf.csnPin = 10;
Mirf.init();
Mirf.channel = 1;
Mirf.config();
//TEMP SENSOR
tempvalue=vout;
//GAS SENSOR
if (gasvalue >= 10)
//Receiver
#include <SPI.h>
#include <Mirf.h>
int buzzer = 7;
float gasvalue;
float tempvalue;
noTone(buzzer);
lcd.init();
lcd.backlight();
delay(5000);
lcd.clear();
Mirf.cePin = 9;
Mirf.csnPin = 10;
Mirf.init();
Mirf.channel = 1;
Mirf.config();
//GAS SENSOR
noTone(buzzer);
lcd.setCursor(0,1);
lcd.print("%");
lcd.setCursor(0,0);
lcd.print("C ");
if (gasvalue >= 10)
lcd.setCursor(0,3);
lcd.setCursor(0,2);
lcd.setCursor(0,3);
lcd.setCursor(0,2);
noTone(buzzer);
lcd.clear();
farriz
June 15, 2022, 5:47pm
7
can u show me which part need to struct?
Example sketches to send and receive a struct
Tx
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <RF24.h>
//not all #defines used but here for documentation
#define CE_PIN 9
#define CSN_PIN 10
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
const byte slaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char txNum = '0';
struct data
byte pinState;
byte temperature;
} sentData;
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000;
Serial.println("SimpleTx Starting");
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.setRetries(3, 5); // delay, count
radio.openWritingPipe(slaveAddress);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis)
sentData.pinState = !sentData.pinState;
sentData.temperature = sentData.temperature + 1;
send();
prevMillis = millis();
void send()
bool rslt;
rslt = radio.write( &sentData, sizeof(sentData) );
if (rslt)
Serial.println(" Acknowledge received");
Serial.println(" Tx failed");
Rx
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
const byte thisSlaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
struct data
byte pinState;
int temperature;
} receivedData;
bool newData = false;
Serial.println("SimpleRx Starting");
radio.begin();
radio.openReadingPipe(1, thisSlaveAddress);
radio.startListening();
getData();
showData();
void getData()
if ( radio.available() )
radio.read( &receivedData, sizeof(receivedData) );
newData = true;
void showData()
if (newData == true)
Serial.print("Data received\tpinState : ");
Serial.print(receivedData.pinState);
Serial.print("\t");
Serial.print("temperature : ");
Serial.println(receivedData.temperature);
newData = false;
system
Closed
December 12, 2022, 5:55pm
9
