Hello, im new to the arduino scene and have a pretty big question
If anybody can help me.
I Want my relay on pin 7 to trigger on when i push DELETE keyboard key and keep on for 3 seconds then go off can anybody help me with this? pleaseee.
Welcome to the forum
Is the DELETE key that you refer to the one on the PC keyboard ?
How is the keyboard connected to the Arduino?
Yes it is
is the keyboard connected to pc
Then you will need software running on the PC that can send a signal to the Arduino that the delete key has been pressed. You presumably do not have such software
Why not simply use a button connected to the Arduino and have the user press that instead of the delete key ?
What problem are you trying to solve by detecting that the delete key has been pressed ?
So the thing that im trying to id is : i stream on tiktok and i want to make my nerf gun (wich i connected to arduino and it works with a timer (turn relay on for 3 seconds and off for 5 seconds over and over ) i wanna make it trigger on with a stroke from my keyboard because i want my viewers to be able to trigger it on through a gift from tiktok gift wich i can program through tikfinity toi simulate a keystroke so rose->DELETE->nerf gun on(relay) for 2 seconds -> nerfgun(relay) off. i dont know if i explained to well .
pinMode(7, OUTPUT);// connected to S terminal of Relay
digitalWrite(7,HIGH);// turn relay ON
delay(3000);// keep it ON for 3 seconds
digitalWrite(7, LOW);// turn relay OFF
delay(5000);// keep it OFF for 5 seconds
That's what i have so far but i need it to get on on a keystroke and then off until the keystroke is pressed again
Can tikfinity output to a serial port on the PC ?
i dont think so, it only simulates keystrokes and trigger webhooks when i get a certain gift.
What do you mean by a webhook ?
I have no idea what that does apart from its name, which I don't like the look of at all
doesn't matter its for a GTA5 so all i need its a method to make arduino turn the relay on when a key is pressed
It seems that tikfinity can connect to an IP address on receipt of a gift from TikTok
If so, then an Arduino board connected to your network could be used as the target of the connection and could receive a payload that could cause the Arduino to run code
Which Arduino board are you using ?
arduino uno
Third-Party API - TikFinity i think it can use ports or execute codes by the seeings here.
If it is a Uno R3 rather than a Uno R4 then it cannot connect to a network without extra hardware such as a network shield
Would you consider buying an ESP32 board ?
Sounds like a job for an UNO-R4 WiFi or an ESP32
Edit: Got ninja posted by UKHB with the same info.
You can never have too much good advice
