Help ATmega328PB upload hex file:
Hello everyone, I have this construction plan and I have assembled a circuit board with it. I used a usbasp and would like to drag a hex file onto the microcontroller. Enclosed are plans and pictures and the error messages that the atmel 328pb is somehow not recognised correctly.
Here is the code to upload:
avrdude -V -c usbasp -p m328pb -P usb -U flash:w:XXX...XXX.hex:i
The error:
Error: program enable: target does not answer (0x01)
Error: initialization failed (rc = -1)
  • double check the connections and try again
  • use -B to set lower the bit clock frequency, e.g. -B 125kHz
  • use -F to override this check
Avrdude done. Thank you.
What OS are you using?
-P usb does not look right to me?
On Windows I would expect COMx.
On Linux it would be something like /dev/ttyUSBx or /dev/ttyACMx
On a Mac it might be /dev/cu.something
Usually avrdude will use the default port for the programmer anyway, chances are you can just drop the -P anyway.
i work on mac, and connect via a usb-c hub
i also tryed: /Users/XX/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/XXX/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -p m8 -c usbasp -P usb -U flash:w:/UsersXXXl/Desktop/usbasp.atmega8.2011-05-28.hex:i
to update the usbasp and it worked. But if i doit on the other: /Users/XXXLibrary/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/XXX/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -p m328pb -c usbasp -P usb -U flash:w:/Users/XXX/Desktop/Beerdrinker.hex:i
i get this error:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "/Users/XXX/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
     User configuration file is "/Users/XXX/.avrduderc"
     User configuration file does not exist or is not a regular file, skipping
     Using Port                    : usb
     Using Programmer              : usbasp
     AVR Part                      : ATmega328PB
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : usbasp
     Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: error: program enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
i also tryed this but it also did not worked:
avrdude -F -V -c usbasp -p m328pb -P usb -b 115200 -U flash:w:/Users/XXX/Desktop/Beerdrinker.hex
    Device signature = 00 00 00 (retrying)
    Error: invalid device signature
    Warning: expected signature for ATmega328PB is 1E 95 16
    Reading 1720 bytes for flash from input file Beerdrinker.hex
    Writing 1720 bytes to flash
    Writing | ################################################## | 100% 0.85 s
    1720 bytes of flash written
No base resistors for your transistors may cause the applied programming signals to be clamped to a Vbe; too low for programming the chip….
Indeed. And no series (current limiting) resistors either for the segments of the 4 x 7 seg display LED90.
It is often easier to use a Max7219 or Max7221 display driver instead of using shift registers, transistors, resistors and your own multiplexing code.
