HELP!!! ATtiny with Arduino Uno
I am trying to program AtTiny with Arduino Uno
I follow this instruction about how to make a Blinked Led with
Attiny
and I made it work. But this is not what I want.
I want to send a string like “HELLO” through ATtiny’s port to Rx port of other chip.
I open Arduno 1.0.6 , select “ATtiny85 /w Arduino as ISP” from Tools/Board and select “Arduino as ISP” from Tools/Programmer
Then using the following code :
#include <SoftwareSerial.h>
#include <Arduino.h>
SoftwareSerial mySerial(3, 4); // RX, TX
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
but when I verify/compile , I always receive this error :
In file included from SoftwareSerialExample.ino:28:
E:\download\arduino-1.0.6-windows\arduino-1.0.6\libraries\SoftwareSerial/SoftwareSerial.h:48: error: expected class-name before ‘{’ token
E:\download\arduino-1.0.6-windows\arduino-1.0.6\libraries\SoftwareSerial/SoftwareSerial.h:92: error: ‘size_t’ does not name a type
E:\download\arduino-1.0.6-windows\arduino-1.0.6\libraries\SoftwareSerial/SoftwareSerial.h:97: error: ‘Print’ has not been declared
SoftwareSerialExample.ino: In function ‘void setup()’:
SoftwareSerialExample:35: error: ‘Serial’ was not declared in this scope
SoftwareSerialExample:45: error: ‘class SoftwareSerial’ has no member named ‘println’
SoftwareSerialExample.ino: In function ‘void loop()’:
SoftwareSerialExample:51: error: ‘Serial’ was not declared in this scope
SoftwareSerialExample:52: error: ‘Serial’ was not declared in this scope
SoftwareSerialExample:53: error: ‘class SoftwareSerial’ has no member named ‘write’
Can anyone help me to solve this problem?
I really appreciate your help.
try swapping them around - SoftwareSerial.h is depending on a few definitions that are not defined yet (but, are in Arduino.h)
