[Help] BH1750 light intensity sensor did not work with Timer1
My purpose is read data from BH1750 light intensity sensor one time after two second. I using Timer1 to counter time. But, it did not work. When I copy body of callback and paste to loop function then my program work correctly. Help me please. Thank so much.
#include <Wire.h>
#include <TimerOne.h>
#define BH175_ADDRESS         0x23
byte buff[2];
void setup()   {
  // initialize the digital pin as an output:
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);    // set the LED off
  Timer1.initialize(2000000);         // initialize timer1, and set a 1/2 second period
  Timer1.attachInterrupt(callback);  // attaches callback() as a timer overflow interrupt
  Serial.println("Testing");
// the loop() method runs over and over again,
// as long as the Arduino has power
  //callback();
void callback()
  Serial.println("check");
  BH1750_Init(BH175_ADDRESS);
  if(BH1750_Read(BH175_ADDRESS) != 2)
    //Light sensor has problem!
    Serial.println("Light sensor has problem!");
    return;
  int lightIntensity = ((buff[0]<<8)|buff[1])/1.2;
  Serial.println(lightIntensity);
int BH1750_Read(int address) //
  int count = 0;
  Wire.beginTransmission(address);
  Wire.requestFrom(address, 2);
  while(Wire.available()) //
    buff[count] = Wire.read();  // receive one byte
    count++;
  Wire.endTransmission();
  return count;
void BH1750_Init(int address)
  Wire.write(0x10);//1lx reolution 120ms
I just found a solution, I use a check variable , when timer is up, the variable will raise and it's condition for loop function read data from BH1750. But, I dont really like it. My code following.
#include <Wire.h>
byte buff[2];
boolean flag = false;
void setup()   {
  //callback();
  if(flag)
      return;
    flag = false;
void callback()
  flag = true;
  int count = 0;
    count++;
  return count;
