Help , Bootloader problem
Hi, Just got my first Arduino("clone* from ebay)
What I dit'nt se was that there was no bootloader installed
Can anyone help me in the right direction
I have a PL2303HX can I use that for ICPS
thanks
peter
(deleted)
Visit
and upload the .pde to your controller. This should burn the bootloader in order to get you started with Arduino.
This is the board I bought http://www.ebay.com/itm/141003124874?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
My programmer i a 5 pin kind without a resetpin like this one
http://www.ebay.com/itm/1pcs-USB-To-RS232-TTL-Converter-Adapter-Module-PL2303-good-/231135667618?pt=LH_DefaultDomain_0&hash=item35d0c265a2, can it be done without a resetpin ?.
About the optiloader sketch it seems you need a working Arduino, or am I wrong ?
(deleted)
which one should I by then.
are you sure there is no bootloader? the ebay link you show says 'arduino compatible bootloader ready'.
Have you tried to load a sketch into it? One way to check is to press the reset, if the led connected to pin 13 flashes twice it is likely there is a bootloader in it.
Connect the arduino to the USB port without the USB to TTL converter. then download the necessary drivers + arduino IDE. In device manager check which COM port the USB host adapter assigned to your arduino. In arduino ide make the necessary settings (COM port + type: UNO). I believe you do not have to bother with the TTL converter. It can be used only if you are using a standalone ATmega328P et cetera.
Well I ask'ed the seller and he said that I will need an usbtiny programmer, so I guess that there is no bootloader.
The problem is , when I plug it in it dos'nt say anything about an arduino In device manager(wich I would expect) so there for it can't find any drivers not even if I try manually from the driverfolder in the IDE folders.
The pwr diode lights up and the pin13 diode flashes every second just like the led-sketch when i plug it in.
(deleted)
Problem solved , It was what spycatcher2k pointet out, the pl2303 driver I needed to install .
Windows 7 can't for some reason find it itself.
So the A is running and I have uploaded my first program, the one and only - blinking led XD
Thanks a lot
peter
