Help!! building a Copy Cat light display
I'm working on a project to help me learn how to use arduino. My project is 'supposed to' remember when I push a button, how long said button is pushed, and the length between button presses; then it is supposed to replay the eight button push sequence.
summarized... it doesn't work.
could someone please explain to me what's wrong with my code.
int ledPin = 12;
int buttonPin = 2;
int firstPress = 0;
int firstDelay = 0;
int secondPress = 0;
int secondDelay = 0;
int thirdPress = 0;
int thirdDelay = 0;
int forthPress = 0;
int forthDelay = 0;
int fifthPress = 0;
int fifthDelay = 0;
int sixthPress = 0;
int sixthDelay = 0;
int seventhPress = 0;
int seventhDelay = 0;
int eighthPress = 0;
int eighthDelay = 0;
void setup(){
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
void loop(){
if(buttonPin == HIGH){
for(; buttonPin == LOW; firstPress++){
delay(1);
for(; buttonPin == HIGH; firstDelay++){
delay(1);
for(; buttonPin == LOW; secondPress++){
delay(1);
for(; buttonPin == HIGH; secondDelay++){
delay(1);
for(; buttonPin == LOW; thirdPress++){
delay(1);
for(; buttonPin == HIGH; thirdDelay++){
delay(1);
for(; buttonPin == LOW; forthPress++){
delay(1);
for(; buttonPin == HIGH; forthDelay++){
delay(1);
for(; buttonPin == LOW; fifthPress++){
delay(1);
for(; buttonPin == HIGH; fifthDelay++){
delay(1);
for(; buttonPin == LOW; sixthPress++){
delay(1);
for(; buttonPin == HIGH; sixthDelay++){
delay(1);
for(; buttonPin == LOW; seventhPress++){
delay(1);
for(; buttonPin == HIGH; seventhDelay++){
delay(1);
for(;buttonPin == LOW; eighthPress++){
delay(1);
for(; buttonPin == HIGH; eighthDelay++){
delay(1);
digitalWrite(ledPin, HIGH);
delay(firstPress);
digitalWrite(ledPin, LOW);
delay(firstDelay);
delay(secondPress);
delay(secondDelay);
delay(thirdPress);
delay(thirdDelay);
delay(forthPress);
delay(forthDelay);
delay(fifthPress);
delay(fifthDelay);
delay(sixthPress);
delay(sixthDelay);
delay(seventhPress);
delay(seventhDelay);
delay(eighthPress);
delay(eighthDelay);
firstPress = 0;
firstDelay = 0;
secondPress = 0;
secondDelay = 0;
thirdPress = 0;
thirdDelay = 0;
forthPress = 0;
forthDelay = 0;
fifthPress = 0;
fifthDelay = 0;
sixthPress = 0;
sixthDelay = 0;
seventhPress = 0;
seventhDelay = 0;
eighthPress = 0;
eighthDelay = 0;
Thanks a ton.
-Me
ItIsMe:
So.......what happens when you load and run your script?
I would throw in a few diagnostic statements which print to serial port. It will probably then become obvious what's wrong. Your code looked OK to me, but then I'm no expert.
BTW format posted code by highlighting it and pressing the # button:
Like this
This is more a "Programming" issue than a "project guidance".... for when you are ready for the next attempt.
You are simply NEVER READING THE BUTTON. Check out the "Button" example again.
And the code might compile, and thus execute, but it does not do what I think you intended :slight_smile: There are several serious errors in it (if what I guess you are trying to do, from the names and layout, is correct)
The code will be much simpler if you use arrays rather then delayOne, delayTwo ... but lets leave that as the last thing to fix.
