Help building Arduino IR based Tachometer
I'm trying to build a simple arduino IR based tachometer for measuring a DC motor RPM. I used the code below, adjusting it to suit my needs. Thing is: I don't know if I'm doing this right, so I would appreciate some tips.
Below are the images of the tachometer I've build:
OBS: The purple LED is the IR emitter, while the another one is the phototransistor (receiver).
I'm using the following code:
 * Optical Tachometer
 * Uses an IR LED and IR phototransistor to implement an optical tachometer.
 * The IR LED is connected to pin 13 and ran continually.
 * Pin 2 (interrupt 0) is connected across the IR detector.
 * Code based on: www.instructables.com/id/Arduino-Based-Optical-Tachometer/
 * Coded by: arduinoprojects101.com
int ledPin = 13;                // IR LED connected to digital pin 13
volatile byte rpmcount;
unsigned int rpm;
unsigned long timeold;
int enableA = 11;
int motorA1 = 10;
int motorA2 = 9;
void rpm_fun()
   //Each rotation, this interrupt function is run twice, so take that into consideration for
   //calculating RPM
   //Update count
      rpmcount++;
  pinMode(enableA, OUTPUT);
  pinMode(motorA1, OUTPUT);
  pinMode(motorA2, OUTPUT);
  digitalWrite(enableA, HIGH);
  digitalWrite(motorA1, HIGH);
  digitalWrite(motorA2, LOW);
   //Interrupt 0 is digital pin 2, so that is where the IR detector is connected
   //Triggers on FALLING (change from HIGH to LOW)
   attachInterrupt(0, rpm_fun, FALLING);
   //Turn on IR LED
   pinMode(ledPin, OUTPUT);
   digitalWrite(ledPin, HIGH);
   rpmcount = 0;
   rpm = 0;
   timeold = 0;
   //Update RPM every second
   delay(2000);
   //Don't process interrupts during calculations
   detachInterrupt(0);
   //Note that this would be 60*1000/(millis() - timeold)*rpmcount if the interrupt
   //happened once per revolution instead of twice. Other multiples could be used
   //for multi-bladed propellers or fans
   rpm = 3*1000/(millis() - timeold)*rpmcount;
   timeold = millis();
   rpmcount = 0;
   //Print out result to lcd
   Serial.println(rpm);
   //Restart the interrupt processing
And those are the RPM's I've measured using this tachometer:
84
157
152
160
131
94
116
115
103
84
197
24
2
0
1
102
154
252
95
27
22
33
120
35
98
149
136
152
150
127
Am I doing something wrong?
Google slotted optocoupler. Perfect for what you are doing
