i have one MIDI-Out socket at my device.
The arduino sends two program.change commands, one on Midi-Channel 1, one on Midi-Channel 2) to this MIDI-Out.
Now i want to connect to devices to this Midi Out. One receives on channel 1, one receives on channel 2.
Can i just solder a MIDI Y-cable?
Or do i need to build one of this MIDI-Thru Boxes containing an optocoupler (GN138) and a hex inverting schmitt trigger (e.g. 74HC14)?
But despite that MIDI Thru is still the right way to do it. You can't just parallel connect a Y-cable because MIDI uses current loops not varying voltages. A Y-cable would be very unreliable if it worked at all.
Don't either of the unnamed things you want to connect to have a MIDI Thru socket?
Then you are obviously not using test equipment to see what a mess you are making with your signal. In technical terms that solution is crap. Typical of the sort of rubbish you find on the internet these days.
And is not MIDI compliant. It might work with some equipment combinations, it might not work with others, it might
work only on hot days with other combinations, or have a high and variable error rate, or suddenly stop working
when it matters most to you. Just bad engineering, don't expect it to be reliable.
ok...sounds reasonable.
I think i will give it a try for a few rehearsal sessions with my band.
If it generates at least one error, i will switch over to a MIDI Thru Box.
Do you have a link to a schematic of a 1-Midi-In - 2 Midi-Out Thru box?
