int led = 13; // the pin that the LED is atteched to
int sensor = 2; // the pin that the sensor is atteched to
int state = LOW; // by default, no motion detected
int val = 0; // variable to store the sensor status (value)
pinMode(led, OUTPUT); // initalize LED as an output
pinMode(sensor, INPUT); // initialize sensor as an input
Serial.begin(9600); // initialize serial
void loop(){
val = digitalRead(sensor); // read sensor value
if (val == HIGH) { // check if the sensor is HIGH
digitalWrite(led, HIGH); // turn LED ON
delay(10); // delay 100 milliseconds
if (state == LOW) {
Serial.println("Motion detected!");
state = HIGH; // update variable state to HIGH
else {
digitalWrite(led, LOW); // turn LED OFF
delay(10); // delay 200 milliseconds
if (state == HIGH){
Serial.println("Motion stopped!");
state = LOW; // update variable state to LOW
and this one
const int pingPin = 12;
//pin which delivers time to receive echo using pulseIn()
int inPin = 13;
//range in cm which is considered safe to enter, anything
//coming within less than 5 cm triggers red LED
int safeZone = 10;
//LED pin numbers
int greenLed = 3, redLed = 2;
// initialize serial communication
//raw duration in milliseconds, cm is the
//converted amount into a distance
long duration, cm;
//initializing the pin states
pinMode(pingPin, OUTPUT);
pinMode(greenLed, OUTPUT);
pinMode(redLed, OUTPUT);
//sending the signal, starting with LOW for a clean signal
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
//setting up the input pin, and receiving the duration in
//microseconds for the sound to bounce off the object infront
pinMode(inPin, INPUT);
duration = pulseIn(inPin, HIGH);
// convert the time into a distance
cm = microsecondsToCentimeters(duration);
//printing the current readings to ther serial display
Serial.print(cm);
Serial.print("cm");
//checking if anything is within the safezone, if not, keep
//green LED on if safezone violated, activate red LED instead
if (cm > safeZone)
digitalWrite(greenLed, HIGH);
digitalWrite(redLed, LOW);
digitalWrite(redLed, HIGH);
digitalWrite(greenLed, LOW);
delay(300);
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
