Help calculating cummulative uptime
Can someone help me with my logic here, I’m not getting something. I want to calculate seconds since boot. Since millis() rolls I want to catch that also. If I know it’s rolled I can track how many times it’s rolled and compensate.
int times_rolled = 0;
long last = 0;
long get_uptime() {
  long mil = micros();
  // If this run is less than the last the counter rolled
  if (last < mil) {
    times_rolled++;
  // Seconds is easy
  long seconds = mil / 1000;
  // Add one the seconds for times rolled also
  seconds += ((times_rolled * 4294967296) / 1000);
  last = mil;
  return seconds;
You talk about millis(), then call micros(). Two different function returning two different times.
Which should you be calling or asking about?
By the way, both functions return a value of type unsigned long, not long.
An easier way may be to use one of the timer libraries and simply increment a variable in the timer function…
http://www.arduino.cc/playground/Main/MsTimer2
// Uptime counter
#include <MsTimer2.h>
volatile unsigned long _Uptime =0;
void updateuptime() {
_Uptime++;
unsigned long getUpTime()
    unsigned long ret;
    // optional: disable interrupts
    cli();
    ret = _Uptime;
    // optional: enable interrupts
    sei();
    return ret;
  MsTimer2::set(1000, updateuptime);
  MsTimer2::start();
   // call getUpTime here.
Just call getUpTime once and a while to retrieve the number of seconds since boot.
