so i recently built a floating bed and wanted led lights under it. I bought a strip of RGB leds and programmed it to react to music using a homemade micro-controller and a arduino nano. This is the code i used:
int val = 0;
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
val = analogRead(0);
if(val >= 20 && val < 66)
analogWrite(9, val * 3.5);
analogWrite(10, 0);
analogWrite(11, 0);
if (val >= 66 && val < 132) // glow green
analogWrite(9, 0);
analogWrite(10, val * 2);
analogWrite(11, 0);
if (val >= 132 && val < 198) // glow blue
analogWrite(9, 0);
analogWrite(10, 0);
analogWrite(11, val * 1.2);
if (val >= 198 && val < 264) // glow orange
analogWrite(9, val - 14);
analogWrite(10, val - 14);
analogWrite(11, 0);
if (val >= 264 && val < 330) // glow cyan
analogWrite(9, 0);
analogWrite(10, val / 2 + 90);
analogWrite(11, val / 2 + 90);
if (val >= 330) //glow purple
analogWrite(9, val / 3);
analogWrite(10, 0);
analogWrite(11, val / 3);
if (val < 20)
analogWrite(9, 0);
analogWrite(10, 0);
analogWrite(11, 0);
delay(100);
Serial.println(val);
Next, I wiped that code and installed a code that allows for the lights the fade in and out randomly.
Here is that code:
#define NR_OF_LIGHTS 3 //defines variables for lights
int pins[NR_OF_LIGHTS] = { 9, 10, 11 };
int values[NR_OF_LIGHTS];
int steps[NR_OF_LIGHTS];
#define NR_OF_FADESTEPS 4 //defines variables for fade
int fadesteps[NR_OF_FADESTEPS] = { 192, 128, 64, 0 };
int fade_delay = 100; // millisec
int fade_cycles = 3000;
int nr_of_blinks = 2;
int blink_delay = 400; //millisec
int effect = 1;
int randomlights[NR_OF_LIGHTS];
bool chosenlights[NR_OF_LIGHTS];
randomSeed(analogRead(1));
for (int i = 0; i < NR_OF_LIGHTS; i++) {
values[i] = (int)random(230) + 13; // start values between 'max min' and 'min max'
steps[i] = (int)random(4) + 1; // steps between 1 and 4
for (int j = 0; j < fade_cycles; j++) {
fadingLight(i);
delay(fade_delay);
if (effect == 1) {
blinkAll();
effect = 2;
else if (effect == 2) {
runningLight(0);
effect = 3;
else if (effect == 3) {
runningLight(255);
effect = 1;
void fadingLight(int i) {
int minvalue = (NR_OF_FADESTEPS * abs(steps[i])) + 1;
int maxvalue = 255 - minvalue;
int fs = NR_OF_FADESTEPS;
for (int j = 0; fs > 0; fs--, j++) {
if (values[i] > fadesteps[j]) {
values[i] += fs * steps[i];
if (values[i] > maxvalue || values[i] < minvalue) {
steps[i] *= -1;
analogWrite(pins[i], values[i]);
void setAllLights(int value) {
analogWrite(pins[i], value);
void blinkAll() {
for (int i = 0; i < nr_of_blinks; i++) {
setAllLights(255);
delay(blink_delay);
setAllLights(0);
delay(blink_delay);
void runningLight(int startvalue) {
setAllLights(startvalue);
for (int j = 0; j < 2; j++) {
randomize();
analogWrite(pins[randomlights[i]], 255 - startvalue);
delay(200);
analogWrite(pins[randomlights[i]], startvalue);
void randomize() {
chosenlights[i] = false;
//first one always ok
int r = (int)random(NR_OF_LIGHTS);
randomlights[0] = r;
chosenlights[r] = true;
//next 4
for (int i = 1; i < 5; i++) {
while (true) {
if (chosenlights[r] == false) {
randomlights[i] = r;
//last one
if (chosenlights[i] == false) {
randomlights[5] = i;
I have a switch and i would like to hook it up to digital pin 2. When it is on i want the lights to fade in and out (second code) and when it is off, react to music (first code). So naturally i did an If command statement. The resulting code goes as follows:
int effect = 1;
char x = analogRead(3);
int val = 0;
int a = 0;
int z = 0;
pinMode(9, OUTPUT);
pinMode(2, INPUT);
z = digitalRead(2);
if(z == 1){
fadingLight(i);
delay(fade_delay);
if (effect == 1) {
blinkAll();
effect = 2;
runningLight(0);
effect = 3;
runningLight(255);
effect = 1;
Serial.println(z);
if(z == 0){
analogWrite(10, 0);
analogWrite(11, 0);
analogWrite(9, 0);
analogWrite(11, 0);
analogWrite(9, 0);
analogWrite(10, 0);
analogWrite(11, 0);
analogWrite(9, 0);
analogWrite(10, 0);
if (val < 20)
analogWrite(9, 0);
analogWrite(10, 0);
analogWrite(11, 0);
delay(100);
steps[i] *= -1;
void blinkAll() {
setAllLights(255);
delay(blink_delay);
setAllLights(0);
delay(blink_delay);
randomize();
delay(200);
void randomize() {
//next 4
while (true) {
//last one
When i ran that code, only the code that faded the lights in and out appeared whether or not the switch was on. Do i need to do my fading code a different way, call each file separately inside of a main code(attaching files), or something else? Any help would be appreciated
music_red_dimmer.ino (1.15 KB)
fading_lights.ino (2.54 KB)
music_dimmer_and_fader.ino (3.79 KB)
