Hello, I am building a project and i need to use the esp8266-01 to get data from the internet and the oled to show the data in real time.
But when i use the library of the oled - #include <SFE_MicroOLED.h>
it appears that the esp8266 cant get the data right.
here some pictures of the problam:
the picture that you can see get the data and transfer it correctly is without including the library and the second that i get the data but it wont translate the data is with the library
i hope someone can help.
and here is the code :
int hour=0;
int minute=0;
int second=0;
int b=0;
#define ESP8266_BAUD 9600 // You may need change it (to 56700, 115200 or other) based on your ESP8266 configuration
// If SoftwareSerial is used:
#define SS_RX 5
#define SS_TX 6
// Uncomment the below line for using Serial1 (for ex. on Arduino MEGA)
#define SW_SERIAL
#ifdef SW_SERIAL
#include <SoftwareSerial.h>
SoftwareSerial ESP8266_PORT(SS_RX, SS_TX);
#else
- On Arduino MEGA, you can choose between three serial ports:
- Serial1 on pins 19 (RX) and 18 (TX)
- Serial2 on pins 17 (RX) and 16 (TX)
- Serial3 on pins 15 (RX) and 14 (TX)
#define ESP8266_PORT Serial1
#endif
#define ONBOARD_LED 12 // Onboard indicator
int button=2;
int led=13;
int bazzer=7;
/* Replace with your AP name/password */
const String ESP8266_APNAME = “Name”;
const String ESP8266_APPSWD = “Pass”;
String ESP8266_CMD;
int CheckButton;
pinMode(led,OUTPUT);
pinMode(button,INPUT);
pinMode(bazzer,OUTPUT);
pinMode(ONBOARD_LED, OUTPUT);
digitalWrite(bazzer,HIGH);
Serial.begin(115200); // Debug port
ESP8266_PORT.begin(ESP8266_BAUD); // ESP8266 port
ESP8266_Init();
void ESP8266_Init()
String ESP8266_CMD, WWWResponse;
Serial.println(“Connecting to WiFi (” + ESP8266_APNAME + “, " + ESP8266_APPSWD + “), please wait…”);
ESP8266_Send(“AT+CWMODE=1”, 100, false);
WWWResponse=ESP8266_Send(“AT+CWJAP=”” + ESP8266_APNAME + “”,"" + ESP8266_APPSWD + “”", 5000, false);
if(find_text(“CONNECTED”, WWWResponse) == 0)
Serial.println(“Error: can’t connect to AP.”);
digitalWrite(ONBOARD_LED, 0);
while(1);
Serial.println(“Ready!”);
if (ESP8266_PORT.available()) {
int inByte = ESP8266_PORT.read();
Serial.write(inByte);
eldad_connect();
while(Serial.available())
Serial.read();
void eldad_connect(){
String hour1;
String minute1;
String second1;
ESP8266_Send(“AT+CIPSTART=“TCP”,“ortyuvali.arduino2web.com”,80”, 1000, false);
ESP8266_CMD=“GET /Eldad/watch/time.txt HTTP/1.1\r\nHost: ortyuvali.arduino2web.com\r\n\r\n”;
ESP8266_Send(“AT+CIPSEND=”+String(ESP8266_CMD.length()), 1000, false);
WWWResponse=ESP8266_Send(ESP8266_CMD, 1000, true);
// Access the file
Serial.println(“accesing hour”);
int idPos=(find_text(“hour”, WWWResponse));
if(WWWResponse.substring(idPos, idPos+4) == “hour”)
hour1 = WWWResponse.substring(idPos+5,idPos+7);
minute1 = WWWResponse.substring(idPos+8,idPos+10);
second1 = WWWResponse.substring(idPos+11,idPos+13);
b=5;
Serial.read();
Serial.println(hour1);
Serial.println(minute1);
Serial.println(second1);
hour = hour1.toInt();
minute = minute1.toInt();
second = second1.toInt();
Serial.println(hour);
Serial.println(minute);
Serial.println(second);
// read from port 1, send to port 0:
Serial.println(“Accessing http://ortyuvali.arduino2web.com/ESP8266/id.txt…”);
ESP8266_Connect();
void ESP8266_Connect()
ESP8266_CMD=“GET /Eldad/value.txt HTTP/1.1\r\nHost: ortyuvali.arduino2web.com\r\n\r\n”;
WWWResponse=ESP8266_Send(ESP8266_CMD, 1000, false);
// Access the file
int idPos=(find_text(“Ring”, WWWResponse));
if(WWWResponse.substring(idPos, idPos+4) == “Ring”)
Serial.println(“Led is on”);
digitalWrite(led,HIGH);
digitalWrite(bazzer,LOW);
CheckButton = digitalRead(button);
while(CheckButton<1){
ESP8266_CMD=“GET /Eldad/fupdate.php?value=not HTTP/1.1\r\nHost: ortyuvali.arduino2web.com\r\n\r\n”; // send to not to the web so it will not continue to vipe
Serial.read();
Serial.println(“Led is off”);
digitalWrite(led,LOW);
// Send command to ESP8266
String ESP8266_Send(String command, const int timeout, boolean debug)
String response = “”;
ESP8266_PORT.println(command); // Send the command to ESP8266
long int time = millis();
while( (time+timeout) > millis())
while(ESP8266_PORT.available())
// The ESP8266 has data, so display its output to the serial window
char c = ESP8266_PORT.read(); // read the next character.
response+=c;
if(debug)
Serial.print(response);
return response;
int find_text(String needle, String haystack) {
int foundpos = 0;
for (int i = 0; i <= haystack.length() - needle.length(); i++) {
if (haystack.substring(i,needle.length()+i) == needle) {
foundpos = i;
return foundpos;
