C++ source file
#include "LCDI2C4Bit.h"
#include "Wire.h"
extern "C" {
#include <stdio.h> //not needed yet
#include <string.h> //needed for strlen()
#include <inttypes.h>
#include "Arduino.h" //all things wiring / arduino
//command bytes for LCD
#define CMD_CLR 0x01
#define CMD_RIGHT 0x1C
#define CMD_LEFT 0x18
#define CMD_HOME 0x02
//stuff the library user might call---------------------------------
//constructor. num_lines must be 1 or 2, currently.
byte dataPlusMask = 0; // TODO!!!
LCDI2C4Bit::LCDI2C4Bit( int devI2CAddress, int num_lines, int lcdwidth) {
myNumLines = num_lines;
myWidth = lcdwidth;
myAddress = devI2CAddress;
void SetMCPReg( byte deviceAddr, byte reg, byte val ) {
Wire.beginTransmission(deviceAddr);
Wire.write(reg);
Wire.write(val);
Wire.endTransmission();
void SendToLCD( byte deviceAddr, byte data ) {
data |= dataPlusMask;
SetMCPReg(deviceAddr,0x0A,data);
data ^= 0x80; // E
delayMicroseconds(1);
data ^= 0x80; // E
delay(1);
void WriteLCDByte( byte deviceAddr, byte bdata ) {
SendToLCD(deviceAddr,bdata >> 4);
SendToLCD(deviceAddr,bdata & 0x0F);
void LCDI2C4Bit::init( void ) {
dataPlusMask = 0; // initial: 0
SetMCPReg(myAddress,0x05,0x0C); // set CONFREG (0x05) to 0
SetMCPReg(myAddress,0x00,0x00); // set IOREG (0x00) to 0
delay(50);
SendToLCD(myAddress,0x03);
delay(5);
delayMicroseconds(100);
delay(5);
SendToLCD(myAddress,0x02);
WriteLCDByte(myAddress,0x28);
WriteLCDByte(myAddress,0x08);
WriteLCDByte(myAddress,0x0C); // turn on, cursor off, no blinking
delayMicroseconds(60);
WriteLCDByte(myAddress,0x01); // clear display
delay(3);
void LCDI2C4Bit::backLight( bool turnOn ) {
dataPlusMask |= 0x40; // Lights mask
if (!turnOn) dataPlusMask ^= 0x40;
SetMCPReg(myAddress,0x0A,dataPlusMask);
void LCDI2C4Bit::print( int value ) {
dataPlusMask |= 0x10; // RS
WriteLCDByte(myAddress,(byte)value);
dataPlusMask ^= 0x10; // RS
void LCDI2C4Bit::printIn( char value[] ) {
for ( char *p = value; *p != 0; p++ )
print(*p);
void LCDI2C4Bit::clear() {
commandWrite(CMD_CLR);
void LCDI2C4Bit::cursorTo(int line_num, int x) {
commandWrite(CMD_HOME);
int targetPos = x + line_num * myWidth;
for ( int i = 0; i < targetPos; i++)
commandWrite(0x14);
void LCDI2C4Bit::commandWrite( int command ) {
// RS - leave low
WriteLCDByte(myAddress,command);
delay(1);
Header file
#ifndef LCDI2C4Bit_h
#define LCDI2C4Bit_h
// IMPORTANT! Wire. must have a begin() before calling init()
class LCDI2C4Bit {
public:
LCDI2C4Bit(int devI2CAddress, int num_lines, int lcdwidth);
void commandWrite(int command);
void init();
void print(int value);
void printIn(char value[]);
void clear();
void backLight( bool turnOn );
//non-core---------------
void cursorTo(int line_num, int x);
//void leftScroll(int chars, int delay_time);
//end of non-core--------
//4bit only, therefore ideally private but may be needed by user
//void commandWriteNibble(int nibble);
private:
//void pulseEnablePin();
//void pushNibble(int nibble);
//void pushByte(int value);
int myNumLines;
int myWidth;
int myAddress;
#endif
Sketch
#include <Wire.h>
#include <LCDI2C4Bit.h>
int ADDR = 0xA7;
;Connect the following pins from MCP23008 to LCD
;P0 - D4
;P1 - D5
;P2 - D6
;P3 - D7
;P4 - RS
;P5 - RW (not used, set to 0 to ground for write)
;P6 - Bl (backlight switch)
;P7 - E
byte x = 0;
byte data = 1;
byte c;
LCDI2C4Bit lcd = LCDI2C4Bit(ADDR,4,20);
Wire.begin(); // join i2c bus (address optional for master)
lcd.init();
lcd.printIn("test");
WriteLCD(ADDR,'a');
lcd.clear();
WriteLCD(ADDR,'c');
lcd.cursorTo(0,0);
lcd.printIn("0");
lcd.cursorTo(1,0);
lcd.printIn("1");
lcd.cursorTo(2,0);
lcd.printIn("2");
lcd.cursorTo(3,0);
lcd.printIn("3");
lcd.backLight(true);
lcd.backLight(false);
Error picture
