I am fumbling my way through a very simple project in which I am placing mico led's in a dress with conductive thread. I am wondering if I might get some feedback on the code, mainly, will this work? Unfortunately I have basically zero programming, electronics experience, this has been quite a painful process. First, for reference, I will cite some of the materials I am using,
LilyPad Arduino 328 Main Board
LilyPad FTDI Basic Breakout Board - 5V
LilyPad LED Micro - White
Conductive thread 28 Ohms/Ft
( For some reason in place of the #8 appears a smiley face, there's no way to fix it in this post :Z )
#define LED1 5
#define LED2 6
#define LED3 7
#define LED4 8
#define LED5 9
#define LED6 10
#define LED7 11
#define LED8 12
#define LED9 13
#define LED10 2
#define LED11 3
#define LED12 4
#define interval 11000
#define dead_time 1000
unsigned long PWM_counter = 0;
int offset = 0;
int step_size = 200;
unsigned long on_time = 0;
unsigned long cycle_start = 0;
char dir = 1;
int offset2 = 0;
int step_size2 = 200;
unsigned long on_time2 = 0;
unsigned long cycle_start2 = 0;
char dir2 = 1;
byte LED_tracker1 = 1;
byte LED_tracker2 = 1;
Serial.begin(57600);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
pinMode(LED5, OUTPUT);
pinMode(LED6, OUTPUT);
pinMode(LED7, OUTPUT);
pinMode(LED8, OUTPUT);
pinMode(LED9, OUTPUT);
pinMode(LED10, OUTPUT);
pinMode(LED11, OUTPUT);
pinMode(LED12, OUTPUT);
offset = random(2500,7500);
offset2 = random(2500,7500);
PWM_counter = micros();
if( (PWM_counter + offset - cycle_start) >= interval) { // completed cycle, start over
on_time += step_size*dir;
cycle_start = PWM_counter;
if (on_time >= (interval - dead_time) ) {
dir *= -1;
on_time = interval - dead_time;
else if (on_time <= 0) {
on_time = 0;
dir *= -1;
LED_tracker1 = LED_tracker2;
while (LED_tracker1 == LED_tracker2) LED_tracker1 = random(1,10);
offset2 = random(0,4000);
else if( (PWM_counter + offset - cycle_start) >= (dead_time + on_time) ) { // time to switch LED off
//digitalWrite(LED1, LOW);
LED_off(LED_tracker1);
else if( (PWM_counter + offset - cycle_start) >= dead_time) { // time to switch LED on
//digitalWrite(LED1, HIGH);
LED_on(LED_tracker1);
if( (PWM_counter + offset2 - cycle_start2) >= interval) { // completed cycle, start over
on_time2 += step_size2*dir2;
cycle_start2 = PWM_counter;
if (on_time2 >= (interval - dead_time) ) {
dir2 *= -1;
on_time2 = interval - dead_time;
else if (on_time2 <= 0) {
on_time2 = 0;
dir2 *= -1;
LED_tracker2 = LED_tracker1;
while (LED_tracker2 == LED_tracker1) LED_tracker2 = random(1,10);
else if( (PWM_counter + offset2 - cycle_start2) >= (dead_time + on_time2) ) { // time to switch LED off
LED_off(LED_tracker2);
else if( (PWM_counter + offset2 - cycle_start2) >= dead_time) { // time to switch LED on
LED_on(LED_tracker2);
void LED_on(byte LED)
if (LED == 1) digitalWrite(LED1, HIGH);
if (LED == 2) digitalWrite(LED2, HIGH);
if (LED == 3) digitalWrite(LED3, HIGH);
if (LED == 4) digitalWrite(LED4, HIGH);
if (LED == 5) digitalWrite(LED5, HIGH);
if (LED == 6) digitalWrite(LED6, HIGH);
if (LED == 7) digitalWrite(LED7, HIGH);
if (LED == 8) digitalWrite(LED8, HIGH);
if (LED == 9) digitalWrite(LED9, HIGH);
if (LED == 10) digitalWrite(LED10, HIGH);
if (LED == 11) digitalWrite(LED11, HIGH);
if (LED == 12) digitalWrite(LED12, HIGH);
void LED_off(byte LED)
if (LED == 1) digitalWrite(LED1, LOW);
if (LED == 2) digitalWrite(LED2, LOW);
if (LED == 3) digitalWrite(LED3, LOW);
if (LED == 4) digitalWrite(LED4, LOW);
if (LED == 5) digitalWrite(LED5, LOW);
if (LED == 6) digitalWrite(LED6, LOW);
if (LED == 7) digitalWrite(LED7, LOW);
if (LED == 8) digitalWrite(LED8, LOW);
if (LED == 9) digitalWrite(LED9, LOW);
if (LED == 10) digitalWrite(LED10, LOW);
if (LED == 11) digitalWrite(LED11, LOW);
if (LED == 12) digitalWrite(LED12, LOW);
