Help choosing Arduino
Hello everyone,
I wanted to ask some advice about the model of Arduino:
The project I'm working is a device with lithium polymer battery, that can "log" data received from GPS on the card (micro SD), temperature sensor and will probably ANT receiver, to receive data from cardio-freq.
What model do you recommend?
P.s
Do you have any advice regarding receiving ANT? What components i can use?
Greetings and thanks
The cynic in me says get an old Duemilanove or clone from Ebay, the official answer is a Uno :wink: You won't need the extra resources or expense of the Mega and the Uno is better supported than the Nano, Pro etc etc.
pluggy:
Hi, thank for the answer but for this device, the size matter, i want the smallest possible. :wink:
Yoda87:
pluggy:
Is that in your original post?
Maybe you should produce all the requirements and then ask for help. If you don't know what you need -- considering the cost is less than $100 for most models the simplest solution might be to "buy and try".
In any case buying a UNO model to prototype and then moving it to a smaller unit might be the simplest approach. iow -- prototyping...
I saw all models, maybe the Arduino Fio is the better product for me, it has the lipo charger inside
Teensy boards are even smaller:
http://www.pjrc.com/teensy/
  • has more resources than the mega328 based boards: more RAM, i/o pins, FLASH & EEPROM
  • REAL USB support so you can emulate any type of USB device by changing sketch,
  • usually cheaper, and well supported.
You do have to mod it to work with 3.3v by adding the 3.3v regulator for
an extra $1.
--- bill
